First engine build! question already! help!
Old Jun 14, 2007 | 01:53 AM
JohnCalvin's Avatar
JohnCalvin
Default First engine build! question already! help!
OK... I finally have all the parts to start and finish my 302 engine build!!! Pics will be coming very soon!
My question is about intake gaskets... I'm going to gasket match my heads and intake. My question is where does the gasket go??? Does it align just the best i can by eye on the heads? then how do i know where it will line up on the intake? The instructions mentioned using a cemet or adhesive to hold it on the heads and let it dry then after drying to put on the intake... any help??? Yes this is my first engine... and this forum is the only way i'm going to make it through!
Old Jun 14, 2007 | 02:06 AM
JMD's Avatar
JMD
Default RE: First engine build! question already! help!
I am farmiliar with gasket matching but I have never done it, but, I would think that you can align the gasket by running bolts through the gasket and into the respective piece you are working on (head or manifold). In the examples I remember, a dye or bluing agent was used to mark the placeswhere the metalwould need to be ground out. An adhesivemight help to keep everything in place, but youmight not be able to use the gaskets for their intended purpose after gluing them down.
Old Jun 14, 2007 | 02:35 AM
JohnCalvin's Avatar
JohnCalvin
Thanks! I've been screwing around with them all night and researching and using the bolts is working really well for me so far! This weekend i should finish the gasket match job and i'll post pics for everyone, i'm going to take pics of the whole build and install so people can learn from me figuring it all out! Thanks again for the reply... i'm going to search for that blue dykem tomorrow.
Old Jun 14, 2007 | 03:47 AM
JMD's Avatar
JMD
Glad to be of help, best of luck on your project, I look forward to seeing your project in pictures here!
Old Jun 14, 2007 | 04:32 AM
andrewmp6's Avatar
andrewmp6
i always run some rtv around the water jackets on both sides. and i dont use them cheap cork gaskets i have always had them leak on me
Old Jun 14, 2007 | 07:29 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: andrewmp6
Yeah, use some blue RTV sealant especially around the water jacket areas. Let the RTV set up and harden for awhile so that it acts like a gasket and not a mushy pile of gel.
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Calizic
Aug 28, 2015 01:46 PM
classic69FB
Aug 12, 2015 11:58 PM
StangMuscle
Aug 12, 2015 07:27 AM
HIS S-197
Aug 10, 2015 05:47 PM
