front parking lights - need help
Old Jun 20, 2007 | 06:45 PM
6566ish's Avatar
6566ish
Default front parking lights - need help
Need some help with the front parking lights. The front parking/turn lights have a ground stud on them. Where does this plug go? Looking at the wiring diagram it seems to go to the headlight connectorbut can't find a receptacle anywhere on the headlight or behind it. See item 57 on the attachment.
Any help would be appreciated.
Thanks,
[IMG]local://upfiles/72360/5B1C1B6A84364B85AA5991DCA0D00F8B.jpg[/IMG]
Old Jun 20, 2007 | 06:52 PM
JMD's Avatar
JMD
Default RE: front parking lights - need help
ORIGINAL: 6566ish
Thanks,
On my son's 66, there are 3 wires that come up from the parking light into the headlight area. There was a double plug that had the running light and signal light wire, and a single wire that was the ground, it had a "bullet connector" on it.
We rewired the entire car, so we just hooked the ground wire to the same ground as the headlight.
So, I guess I don't really know the "right" way to handle this, but I do know how to make it work.....
Timetravelinn's Avatar
Timetravelinn
yeah there sould be two connectors to the headlight harness just like in the picture.....did you take the headlight out and look at all the wiring behind it. It could be tucked hidden somewhere.
Old Jun 20, 2007 | 08:18 PM
66GTKFB's Avatar
66GTKFB
The left hand light ground is attached to the top screw of the regulator, the right hand ground is in the radiator support by the battery.
Jim
Old Jun 21, 2007 | 02:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here are a couple of pics. As far as the ground wire goes, ground is ground.
[IMG]local://upfiles/10034/599C5DB51EC245058BD6A06AAE5E0A13.jpg[/IMG]
[IMG]local://upfiles/10034/E824F3C77839425283CA087537C63288.jpg[/IMG]
TfcCDR
Sep 14, 2015 12:08 PM
Sparks_88
Sep 8, 2015 01:06 PM
amandahchase
Sep 3, 2015 10:09 AM
