towing my stang
Old Jun 20, 2007 | 06:57 PM
krauter65's Avatar
krauter65
Default towing my stang
i need to get my project out of storage and into my garage. at the time i need to move it i only have access to a two wheel dolly. no brakes on my car so i cant just tow it. will i need to tow it from the front or from the rear. any input is very appriciated.
Old Jun 20, 2007 | 07:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: towing my stang
id pull the d/s and plug the tranny(if its an auto) in the rear, you can leave the d/s in as long as you arent going long distance say less than 25 miles
Old Jun 20, 2007 | 07:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
It can be pulled from the rear for a short distance. I had mine pulled about 5 miles from the rear one time and not damage occured. However, the recommended direction is from the front. If it is a manual transmission, just put it in neutral. If it is an automatic, then go ahead and pull the drive shaft off and pull it from the front if it is more than 5 miles or so.
Old Jun 21, 2007 | 09:20 PM
snydes65coupe's Avatar
snydes65coupe
if you tow it by the front make sure the rear end is full of oil, my friend towed his car about 1 mile and the rear end locked up when they were towing it.because it had no oil in it. he thought the other guy filled it up and he thought someone else filled it up.
Roxon68
Mar 17, 2016 08:13 PM
Bokeo
Oct 10, 2015 08:28 PM
Meystang
Sep 25, 2015 04:05 PM
sjforcup19
Sep 15, 2015 09:58 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
