rear shocks question
Old Jun 21, 2007 | 09:34 PM
tony 72 conv's Avatar
tony 72 conv
Default rear shocks question
i cant seem to find where the top part of the rear shocks bolt on just by taking a quick look
i removed the back seat,and its not there,looked where the convertible tops goes down into and its not there. do i need to remove the back of the back seat?
Old Jun 21, 2007 | 10:03 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: rear shocks question
Under a rubber plug in the trunk just behind the rear seat back.
Old Jun 22, 2007 | 06:32 AM
mat11089's Avatar
mat11089
Get a haynes,chiltons, or some repair manual.Looks like youre gonna need it.Good luck
Old Jun 22, 2007 | 09:01 AM
dozierstang's Avatar
dozierstang
Yes, you have to remove the seat back in order to gain access to the shock nuts. There should be rubber oval plugs but sometimes there is none.
Old Jun 22, 2007 | 01:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
Is it the same on a vert as it is on my coupe?
Old Jun 22, 2007 | 02:25 PM
66GTKFB's Avatar
66GTKFB
Yup.
Jim
Old Jun 22, 2007 | 05:30 PM
mayner's Avatar
mayner
The same.
I just did this job. Went pretty well. I removed that petroleum based sticky crap, took off the plugs and discovered that one of the shocks top fastener had backed off and was allowing the top of the shock to piston up and down past the mount.
Explained the "bang!" from the rear of the car everytime I went over a dip in the road.
The front shocks were even easier. Front springs and rear leafs are next. I'm having a shop install all new polyurethane bushings as I type. Didn't want to do that myself. ;-)
Old Jun 22, 2007 | 06:09 PM
highhilleer's Avatar
highhilleer
ORIGINAL: mayner
If you're putting polyurathane bushings on the strut rods, you might want to do some web surfing on the subject. Many think the polyurathane is too hard resulting in strut rod failure.
musnicki
Sep 23, 2015 07:11 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
Sep 1, 2015 08:16 PM
