3 SPEED SWAP TO 4 SPEED
Old Jun 22, 2007 | 06:21 PM
onegreedy's Avatar
onegreedy
Default 3 SPEED SWAP TO 4 SPEED
I have a little problem, the 67 stang i bought the 3 speed is wasted, i have axcess to a 4 speed out of a different mustang to use until my t5z is built, what would need to be changed to put in the 4 speed if anything ?
Old Jun 22, 2007 | 06:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 3 SPEED SWAP TO 4 SPEED
What engine do you have in there?
Old Jun 22, 2007 | 06:35 PM
onegreedy's Avatar
onegreedy
351 w but it still has the stock 289/ 3 speed bell housing
Old Jun 22, 2007 | 06:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Since you need to replace the trashed 3 speed manual anyway, drop it on the floor along with the bell housing and get that 4 speed top loader onto that bell housing if you can. Not sure about the bolt pattern and the number of bolts. What you need to confirm is... bolt patern...box to bellhousing, then input shaft length, face of box to end of input shaft. The input shaft spline should be the same, but also needs to be confrimed.
As far asI am aware, the 3 speed and 4 speed toploaders share the same housing/clutch splines. You should already have a 10" clutch, so you should be good to go there.
mungodrums
Sep 29, 2015 09:18 PM
musnicki
Sep 23, 2015 07:11 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
jaiidutch
Sep 14, 2015 10:29 AM
vintageaion
Sep 8, 2015 10:45 AM
