Needing to Strip Intake Manifold??
Its an Alumminum intake .
ports look to be in great condition ..
just the intake is painted blue .
but its faded ..so i assume when they say needs to be stripped .. it means the paint it has so it wont look all faded and ugly right ?
the intake is in good shape
Now that you've added the material to the question, you might consided a paint remover like Jasco, available at Home Depot, and then some polishing. Or try a machine shop and get it hot tanked - not for a long time - which will loosen up internal crud. Wash itoff with water and like Jeff (gothand) says, check your mating surfaces.
Jim
Jim
Aircraft remover works great, it will get the paint and the crud.
Get the real stuff, aircraft remover comes in two varieties, regular, and enviro friendly, regular works better.
