Disc Brake Conversion on 66 Coupe
Old Jun 23, 2007 | 12:21 AM
dogma_5's Avatar
dogma_5
Default Disc Brake Conversion on 66 Coupe
It's me again. Got another question. My understanding is the front disc brake conversion that was put on my 66 was from CJ Ponies. A question about that if anyone knows about them. It is my understanding that there is a spacer near the inter race that has off set the rotors so they don't line up with the calipers. Does that make sense to anyone. If so, how do you get this spacer out? I don't have the car home yet so I can't take it apart and see for myself. Was just trying to get suggestions before I tore into it. The previous owner claims that CJ tech support told him it can be knock out with a hammer (rubber).
Any thoughts?
Thanks,
Ron
Old Jun 23, 2007 | 12:27 AM
66JameStang's Avatar
66JameStang
Default RE: Disc Brake Conversion on 66 Coupe
What spaer are you talking about do you have pictures when i did mine I did not use a spacer.
Old Jun 23, 2007 | 12:28 AM
baddog671's Avatar
baddog671
The inner grease seal? What kind of conversion is on it?
Old Jun 23, 2007 | 12:30 AM
dogma_5's Avatar
dogma_5
It has already been converted but the calipers are out of aligment with the rotor, not properly centered on the rotor. The lines were all changed, the master cylinder was done as well aproportion value added. Just had no idea were the spacer would be on the inner race?
Old Jun 23, 2007 | 12:35 AM
66JameStang
so the spacer that you are talking about is behind the rotor? If that is the case then there is some dissasembly required. It is not too bad to take apart the brakes themselves.it could be an alignment issue of how the caliper is sitting as wellso can make a mistak in assembly that will affect the offset of the caliper to the rotor.
lincolnshibuya
Oct 6, 2015 08:45 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
