Stainless polish
Old Jun 27, 2007 | 07:31 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Default RE: Stainless polish
You could also try White Rouge ( it's a buffing compound) on cotton buffing wheelwith an electric drill.
Old Jun 28, 2007 | 01:09 AM
gothand's Avatar
gothand
ORIGINAL: ALMOST STOCK
I have a two-wheel buffer with medium and soft wheels as well as white and red rouge, respectively, but haven't tried it on stainless. Maybe I'll do a test run on a butter knife.
Old Jun 28, 2007 | 02:27 AM
andrewmp6's Avatar
andrewmp6
stainless is just like alum you can polish it so it shines like chrome but to me stainless stays polished longer.something to think about after you shine them up try some zoop seal on it. zoop seal will keep it nice and shiney for 6 months to a year after that a light polish and re zoop seal it.
Old Jun 28, 2007 | 11:28 AM
68EFIvert's Avatar
68EFIvert
I just started polishing my trim last night. The scratches I hit with wet sandpaper 1000 then 1200 then 1500 grit. Then took it to the polishing wheel for a shot with Tripoli compoind followed by white rouge. They look pretty stellar if you ask me.
Old Jun 28, 2007 | 07:07 PM
ALMOST STOCK
And if they're just superficial scratches you shouldn't need to use sandpaper, just use the Tripoli and then the White Rouge on a buffing wheel.
Old Jun 28, 2007 | 07:39 PM
68EFIvert's Avatar
68EFIvert
+1, I had a few scratches that were deeper and needed a little more attention. No sandpaper on most of it.
Old Jun 29, 2007 | 10:02 AM
67 evil eleanor's Avatar
67 evil eleanor
Deep scratches will have to be sanded. Use a DA sander. If theres any dints or dings, you can hammer them back out. Be careful as not to over do it. Make sure you have something heavy behind the piece when you tap out the dent. An Anvil of heavy Vise thatis mounted works good.Take your time.Oncethe dent is removed, sand with a DA. I have started with 280 with light pressure on very deep scratches. the deeper the scratch, the more pressure you will need. Then 400, 800, and 1000. After you have sanded and finished up with the 1000 (or higher), it will only take a couple of passes under the buffer (2 wheel high speed floor mounted). Start with the Black and then finish with the white rouge (cleaning the wheel often with anold screwdriver). Careful not to loose a finger. Wear leather gloves and a mask and eye protection.
tmdm
May 2, 2021 02:49 PM
baddog671
Jul 26, 2016 01:20 PM
folivier
Sep 26, 2015 02:28 PM
Sep 24, 2015 09:18 PM
Sep 10, 2015 08:39 PM
