Radiator fluid level question
Old Jun 27, 2007 | 09:31 PM
JoeMustang's Avatar
JoeMustang
Default Radiator fluid level question
My 302 has a stock radiator with a small, round overflow installed by the P.O. When the engine was cold, I took therad cap off to check the coolant. It was about an inch below the neck, but still covered thefins. The overflow has a knurled top, but I didn't try totake itoff. Does the coolant expand when it's hot, then forcing the coolant into the overflow?? And then as it cools, it draws it back into the radiator?Should the overflow be empty when it's cold??
Thanks
Old Jun 27, 2007 | 09:48 PM
66GTKFB's Avatar
66GTKFB
Default RE: Radiator fluid level question
Yes and yes. Check to see if the hose/tube from the radiator go in the overflow at the bottom and are not cracked, otherwise when your engine cools, it won't draw coolant back into the radiator.
Jim
Old Jun 27, 2007 | 11:40 PM
VintageBlue's Avatar
VintageBlue
I don't think the resivoir should be completely empty when it is cold, although I am kind of new to the older carbed engines...but the rest of your assumptions are correct.
Granatelli Sales
Jan 20, 2020 12:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
