flexplate or flywheel
Old Jun 30, 2007 | 02:32 AM
Stevetra's Avatar
Stevetra
Default RE: flexplate or flywheel
You may very well be correct, as I said, I may be wrong.
here is where I got the info:
http://www.carcare.org/Auto_Transmis...lexplate.shtml
Old Jun 30, 2007 | 02:37 AM
my77stang's Avatar
my77stang
ok, well never EVER use that source to help you work on your car LOL
Old Jun 30, 2007 | 10:53 AM
Soaring's Avatar
Soaring
I ♥ Acer
It's called a flexplate flywheel and the ring gear is on it.
Old Jun 30, 2007 | 12:05 PM
Stevetra's Avatar
Stevetra
Well, I stand corrected.
Not that I didn’t trust the “dude your wrong, trust me†argument. I have always been one who liked a more technical consensus when answering a question.
From my checking…yes a flywheel is normally associated with a Manual transmission and a flex plate is normally associated with the automatic.
It also seems that the words are interchanged quite a bit based on who is speaking.
The flex plate is similar to the flywheel. The flex plate is not as strong and as thick as the flywheel. The flex plate is used with the automatic transmission where the torque converter is a unit fixed to the flex plate.
The flywheel is thicker and stronger is designed to take the repeated abuse of the clutch engagement and disengagement, and its weight helps maintain rpm through shifts due to its inertia.
Both the Flex plate and Flywheel act to transfer power from the engine to the transmission.
Old Jun 30, 2007 | 12:38 PM
my77stang's Avatar
my77stang
^ exactly
Old Jun 30, 2007 | 01:22 PM
66GTKFB's Avatar
66GTKFB
Just for the record, Ford called them all flywheels in the 65 to 72 service parts book. Flexplate is not mentioned. I'll still call the thing a flexplate to indicate it goes on an engine with an automatic transmission and I imagine that the guys behind the parts counter will understand, and that's what counts.
Jim
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
