kickdown lever leaking?
Old Jul 1, 2007 | 09:33 PM
mySAVIOReigns's Avatar
mySAVIOReigns
Default kickdown lever leaking?
Ok, well I think I finally have the tranny pan fixed from leaking. Woo hoo!
Now onto leak #2. Fluid is coming out of the "area" where the kickdown cable connects to the transmission. What exactly is that called, the manual lever? And second of all, if I wanted to change those gaskets, or whatever else may be in there, where could I find a kit? Thanks,
Old Jul 1, 2007 | 10:10 PM
66GTKFB's Avatar
66GTKFB
Default RE: kickdown lever leaking?
It's called - replace from the inside.
Jim
Old Jul 2, 2007 | 12:35 AM
mySAVIOReigns
It's called what? I've attached a pic, though, this is my first try at it, so it make take a few attempts.
Screw it: here is the link
Note, the pan is new (and nice and shiny! ). You can see what is circled. That is the thing that is leaking. It drips about 1 time every 30 minutes.
I don't know what exactly I need to replace to get it to stop leaking. It appears there is about 3 bushing or so, and a couple washers and pins. Any idea?
Old Jul 2, 2007 | 02:03 AM
66GTKFB's Avatar
66GTKFB
Where ever you have a seal, it will eventually leak. You said you have a leak at the kickdown lever 'area'. It's where the shifter arm goes into the transmission, as well as the kickdown lever shaft. To replace the seals, you must dissassemble the transmission and replace the seals from the inside. Simple, right.
Jim
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
