temp sensor loacation
Old Jul 3, 2007 | 12:52 AM
hotrod351's Avatar
hotrod351
Default temp sensor loacation
im getting a spal electric fan next week with the adjustable box and a spal temp sensor. im thinking of putting the spal sensor in the plugged hole in the top of the thermostat housing. that way i can keep my original temp sensor in the stock location on the intake manifold. any thought on using this location for the spal sensor.
Old Jul 3, 2007 | 12:56 AM
JMD's Avatar
JMD
Default RE: temp sensor loacation
That is what I would (will) do.
To me it seems to be perfect location.
Old Jul 3, 2007 | 01:04 AM
Aussie66Fastback's Avatar
Aussie66Fastback
+1 makes sense to me.
Old Jul 3, 2007 | 01:05 AM
JamesW's Avatar
JamesW
ORIGINAL: hotrod351
If you've got a plugged hole there that you can just open and install... that should be fine. Depending on the intake manifold, you may have other 1/2 npt fitting locations existing. I'd use one of them before removing the thermostat housing and drilling if there's not already a threaded hole there.
Old Jul 3, 2007 | 02:32 AM
hotrod351's Avatar
hotrod351
the only other port on the intake is for the heater hose, which is hooked up. the stock thermostat housing already has a allen head screwed in plug. i tried removing it when i wanted to put in mech. temp gauge, no luck, its aluminum and i think the screwed in plug is aliminum. any i went to checker and bought a new cast iron housing with the same screw in plug, not installed, so ill swap out the housing, hell it was only $6.00.
Old Jul 3, 2007 | 06:19 AM
Soaring's Avatar
Soaring
I ♥ Acer
I bought a thermostat housing a few months ago, and the damn thing was made in China. BUT.....it had the plug you could remove to put in a water temp gauge. They are available.
[IMG]local://upfiles/10034/70FA8A1CCDA04671BD31EC2D506EFACF.jpg[/IMG]
Old Jul 3, 2007 | 02:01 PM
hotrod351's Avatar
hotrod351
thats the same one i just bought.
Old Jul 3, 2007 | 02:04 PM
boogerschnot's Avatar
boogerschnot
ORIGINAL: hotrod351
Me too!! It was hell to get the thing to stop leaking though,, It took lots of teflon... I should have got the chrome one..
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
TfcCDR
Sep 14, 2015 12:08 PM
96stang3.8
Sep 10, 2015 06:42 AM
