Gauge Replacement
Old Jul 6, 2007 | 05:41 PM
DCStang65's Avatar
DCStang65
Default Gauge Replacement
The fuel, oil and temp gauges in my 1965 are not working. Anyone ever replaced them, and is it difficult? Should I leave this to the pros?
Old Jul 6, 2007 | 05:53 PM
66GTKFB's Avatar
66GTKFB
Default RE: Gauge Replacement
Go to the FAQ section and look up the wiring for you car. You will need this to locate the constant voltage regulator on the back of the instrument cluster which is commonto the gauges that don't register and the item most likely to fail.
Jim
Old Jul 6, 2007 | 05:57 PM
DCStang65's Avatar
DCStang65
Would a failed regulator impact ALL the gauges, including the speedometer?
Old Jul 6, 2007 | 06:09 PM
66GTKFB's Avatar
66GTKFB
Two different thing, the speedometer is mechanical, the others are electrical.
Jim
Old Jul 6, 2007 | 06:30 PM
DCStang65's Avatar
DCStang65
OK. Stupid me. Went to the FAQ section and couldn't find what you recommended (wiring). Can you direct? Sorry.
Old Jul 6, 2007 | 06:32 PM
urban_cowboy's Avatar
urban_cowboy
I have used these guys in the past to clean up my '88 Bronco cluster and get everything tweaked and working right. An old cluster can be a very very sensitive thing. I know mine is going to get sent off in the year.
http://www.instrumentclusters.com/
Give them a shout. They are pretty fast and very reasonable.
Old Jul 6, 2007 | 08:26 PM
66GTKFB's Avatar
66GTKFB
Try this one from the FAQ section - http://www.midlife66.com/wiring/wiring.html
Most of the wiring is similar to the 66 for that voltage regulator.
Jim
mtgldr
Feb 3, 2024 09:00 PM
StalkerGT
Sep 25, 2015 02:41 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
