tach wiring question
ok, so im 99% done with my interior wiring, anyways, i have 4 wires from my tach, black ones goes to chassis ground, green one to negative side of coil, white one goes to light switch, and the red one needs to go to a 12v source, such as anything that turns on when car starts. or to the fusebox, problem, i cant think of anything that will turn on when car turns on, and i cant think of how i have to attach it to the fusebox. theres not how to in these instructions. anyone know?
Switched. There may be one under your dash already but I can't be sure, you can look and probe.(Female round, just to the right of the colume under dash). The old test light will show if its key active. I would fuse it also (5amp inline).
i talked with my dad and he said the radio might not be the best place, so sometime this week we are going to find a wire for it to go on, other then radio its my last thing to do in the interior
There should be an ACCY fuse (accessory) position in your fuse panel. Follow the wire coming from that position. It may have a blank place to plug in a connector. Look for that.
