Converting to 9" Rear end. Need Help!
Old Jul 8, 2007 | 08:24 PM
takeoutexodus's Avatar
takeoutexodus
Default RE: Converting to 9" Rear end. Need Help!
Ok, So i guess i might stick with the 8".
I was wondering the measurement i need .. i think its a 52 and a quarter am i right ?
how cheap can i get one ?
Old Jul 8, 2007 | 08:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: takeoutexodus
Nah, that's a real stupid measurement, The measurement you need to take is from flange to flange. It is 57.25 for the 65-66 and 59.25 for 67 and up. How cheap you can get one is up to you.
Old Jul 8, 2007 | 09:16 PM
takeoutexodus
ok so 57.25 .
to completely make my car handle that 351 .
i have to change entire rear end right ? driveshaft, springs im guessing ... and such as ...
what am i forgetting ..
A list of things to change would be great .. thanks
Old Jul 8, 2007 | 09:28 PM
66GTKFB's Avatar
66GTKFB
Your wheels are now five bolt on the rear axle. Oops, the front ones are still four bolt. You need to convert the front suspension to a V8 type and that includes brakes all around.
Jim
Old Jul 8, 2007 | 09:33 PM
superdavid's Avatar
superdavid
This is not going to be cheap... adding power and V-8's never is. Get ready to fork out some cash....
Old Jul 8, 2007 | 09:46 PM
takeoutexodus
yeah i understand .
ok .. so front and rear conversion all around .
ok ...
that means i have to get new wheels ... ughh.
i had just gotten new 4 bolt ones .
but ehh .. i can sell them ..
Old Jul 8, 2007 | 09:51 PM
JamesW's Avatar
JamesW
Engine
Trans
Driveshaft
Rearend
wheels
suspension
brakes
Steering
electrical
cooling
Fuel system
All of these things have to be evaluated and worked in concert when doing a 6 to 8 swap.
You need to do some research. Surf the net rather than as each question. Google Mustang 6 to 8 swap ... Read the FAQs... Spend a week gathering and learning. THEN, come back and ask your specific questions.
I'm not trying to discourage you, but you need to do the work to learn it first....not just ask and expect to be spoon fed.
Old Jul 8, 2007 | 10:11 PM
Soaring's Avatar
Soaring
I ♥ Acer
JamesW can you instruct me in how to change my oil and filter? What oil should I buy and why should I buy that particular oil? I also have a black bag on my engine bay with water in it..It says '
FOMOCO.What is that for?
Old Jul 8, 2007 | 10:20 PM
66GTKFB's Avatar
66GTKFB
Replace the water with JD No. 7 Sour Mash.
Jim
Old Jul 8, 2007 | 10:22 PM
superdavid's Avatar
superdavid
Soaring, for oil, just dont even worry about it; putting oil in your motor is sooooo over rated. As for the filter, just take it off with a pry bar, shake it vigoriously, then tap it back on with a hammer. That breaks up all the contaminants that it has trapped. The small black bag that say fomoco is acually a misprint, it should read "mofupu" which stands for "mother fu--er pull over" cuz its acually a pee bag in case you have to hand it to your passenger who's weak bladder wants you to pull over.
Dragonus18
Sep 9, 2015 01:21 AM
spamedic
Sep 9, 2015 12:15 AM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 1, 2015 08:16 PM
