my engine is almost done.. possible problems
Old Jul 12, 2007 | 11:47 AM
gothand's Avatar
gothand
Default RE: my engine is almost done.. possible problems
It certainly doesn't look copasetic. If it is already torqued down in the picture, it appears that it is bound up somehow. Like I posted above, I had to do a little clean up on the edge of the casting to get mine to seat properly.
Old Jul 12, 2007 | 12:37 PM
RobbieG.'s Avatar
RobbieG.
Has the heads or intake been flycut at all. It looks like the angle is off.
Old Jul 12, 2007 | 12:43 PM
JMD's Avatar
JMD
ORIGINAL: my77stang
i GOTTA ask.... why add a blower to a motor with stock heads, hell - stock rocker arms and valve springs. seems like overkill for your setup
I don't know, The blower on top of those heads should pump plenty of air into that engine regardless of the heads, and the OP should have plenty of torque/HP down low so that the valve trainshould be sufficient, and need not be in a configuration for high RPM opperation.
Sure the car would make more power with further mods, but I think it will rum well without them.
Old Jul 12, 2007 | 02:27 PM
67SuperSnake's Avatar
67SuperSnake
ORIGINAL: RobbieG.
+1
If you have had the block or heads miiled, then sometimes you need to mill the intake manifold.
Old Jul 12, 2007 | 03:01 PM
groho's Avatar
groho
one of the items mentioned by the ole blue bloodedgrease monkey's, is to be careful with the front/rear intake gasket, because it will want to creep, dislodgeand drop into the valley when you put the intake on.
encourages the use of gasket cinch (adhesive). Looks like that's whathappened to you. Be sure the gasket is eventhere, and hasn't dropped. BTW, have the heads be milled?
Old Jul 12, 2007 | 03:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
There appears to be something terribly wrong with that gap. Not sure if it is a warped intake or head or just what, but that gap is just too wide to be normal. There's not enough blue ATV to fill that huge gap.
Old Jul 12, 2007 | 03:36 PM
eep4life's Avatar
eep4life
i dont know what flycut is... but now that i think about it.. i did get the heads resurfaced when i took them to get ported and polished... would that make a differance....
Old Jul 12, 2007 | 03:43 PM
RobbieG.'s Avatar
RobbieG.
Yep, thats the same thing. If they took to much off, the intake wont match up. You probably need to get the intake cut to match.
Sorry...Flycut is aerospace....decked is automotive
Old Jul 12, 2007 | 03:54 PM
eep4life's Avatar
eep4life
alright.. so when i take it in to be resurfaced should i take the heads with me so the can match the angle?
Old Jul 12, 2007 | 04:00 PM
RobbieG.'s Avatar
RobbieG.
Last time I had to have an intake done, I took them the whole motor on a stand and had the test fit it untill it was right.
Give them a call and see howthey want to do it.
