Distributor, First start question
Old Jul 14, 2007 | 09:39 AM
JohnCalvin's Avatar
JohnCalvin
Default Distributor, First start question
OK, i have a brand spankin new 302 roller sitting in my mustang as of yesterday! Now I have the distributor installed at TDC on the compression stroke and the distributor on the # 1 cylinder. Now someone mentioned i should move it 10 degrees clockwise to help it start up... Is this true? Anything else i should do before the first start? I've already primed everything, fuel, oil... etc. Thanks for the help... this forum is awesome, I couldn't have done the engine swap with out you guys!
Old Jul 14, 2007 | 10:00 AM
Cargon's Avatar
Cargon
Default RE: Distributor, First start question
According to thecarsource.com it's 6 degrees of initial advance.
http://www.thecarsource.com/fords/engines/302.html
Old Jul 14, 2007 | 10:56 AM
JohnCalvin's Avatar
JohnCalvin
Great wedsite, thanks!
Old Jul 14, 2007 | 11:02 AM
JMD's Avatar
JMD
The right way to do it would be to set the timing before starting, but once I get a distributor like you have it, I leave the dist snug, but not tight, turn the engine over, and methodically move the dist case back and forth untill the engine fires, turn the distributor to a point where the the engine will run, and then use the light to set the timing.
Sometimesthis will give me a few backfires, and a couple of "no starts", but it dosent take long to "find" enough timing to make it run.
GimpyHSHS
Aug 29, 2015 06:30 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
Calizic
Aug 28, 2015 01:46 PM
movielover40
Aug 27, 2015 10:13 PM
Philhampton1
Aug 21, 2015 12:04 PM
