suspension upgrade
ORIGINAL: baddog671
That tire size is pretty small, you shouldnt be rubbing unless your suspension is collapsed. Maybe its soft enough that your rubbing the suspension snubber, which would explain it being louder in turns since the shifting weight would push more.
Blue, the 677 was also without shipping since I could drive and it would have been outrageous. And, the prices have gone up alittle so you wont be getting it that cheap...
Ill give you a list when I get on my home computer...
Edit: Oh, and you never specified if you are getting the Granada swap or not. The 600 bucks makes me think your considering the kit from Degins though. If so, those wheels will not fit. You'll need minimum of 15"
You said the tire is a 205/70-14, which is a 25.3" diameter tire. I'm assuming those are 7" wide rims, but could be 8"... That is the exact same diameter as my 215/55-16s in my signature pic below. Mine do not rub, and are 7" rims, because they have a 4" backspacing that draws them in under the fender lip. If you have 3.75" backspacing or less, then this is the reason your rubbing....not because of the suspension.
Do you know how to measure backspacing?
do you want oem replacement or spend a little more and make it handle alot better.cheapest front disc is the Granada swap and there also oem replacement disc kits but they are a little more money.
ORIGINAL: JamesW
best to take the wheel off and measure like this. If it's really 2"... there's no way to make those Keystones work.
Did you take the wheel off the car and measure from the backside (inside) of the wheel? Or from the outside of the wheel? You have to measure from the inside.
Not to be disrespectful, but there's no way those front wheels are 4.5" BS unless they were custom made.
ORIGINAL: JamesW
