pas window regulator
Old Jul 19, 2007 | 08:38 AM
onegreedy's Avatar
onegreedy
Default pas window regulator
hi guys my pas window just cranks and does not move, i removed to make sure the handle is not stripped so i am now trying to figure out to change this out ?
67 coupe
Old Jul 19, 2007 | 09:00 AM
dnswwood's Avatar
dnswwood
Default RE: pas window regulator
First pull the armrest, handle,and door panel off ,then you can see down inside and find out whats going on.
Jeff
Old Jul 19, 2007 | 09:02 AM
mySAVIOReigns's Avatar
mySAVIOReigns
should be held on by a bolt of some sort, remove the handle, remove the arm rest, remove the door panel, then look inside. See if you see anything that is out of the ordinary. Don't have a picture on me, but you'll find it in one of the assembly diagrams or an exploded view diagram
edit, you beat me to it Jeff...
Old Jul 19, 2007 | 02:31 PM
jlg2002's Avatar
jlg2002
There are plastic rollers that are attached to the widow from the regulator and sissor crossarm. You need to pull the door panel and look what's moving or not moving and Then fix it accordingly. California mustang has a picture of the mechanism on page 156 of their 2007 catalog.
Soaring's Avatar
Soaring
I ♥ Acer
Sounds like a new regulator is in order. Be sure to lubricate everything in there real well before you button it up.
Old Jul 19, 2007 | 02:37 PM
66GTKFB's Avatar
66GTKFB
Good reproduction regulators run about $65. Don't bother with the cheap ones. If you can find a decent used one, that would be my first choice. Consider getting a couple of plastic windor rollers because they usually are busted.
Jim
Old Jul 20, 2007 | 12:47 AM
Shifty101Easy's Avatar
Shifty101Easy
ohhh yes....window regulators...almost as fun as block sanding.....
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
stangin1996gt
Sep 21, 2015 11:01 AM
cbird1177711
Sep 3, 2015 08:43 PM
