Door lock issue
Old Jul 19, 2007 | 05:35 PM
thunderize's Avatar
thunderize
Default Door lock issue
If I lock my drivers side door wether it be with a key or push the ****, I cant get it to unlock. It feels like it is jammed. The only way I can get it to unlock is by pulling door panel and doing it manually. There is a lever inside that I can only feel not see and it only takes a slight flip and it opens the door. I have lubed it very well! Is my latch bad or do I have a bent rod? Or what? Thanks
Old Jul 19, 2007 | 05:39 PM
66GTKFB's Avatar
66GTKFB
Default RE: Door lock issue
Take out the mechanism and do an eye-ball check. Three rods and three screws.
Jim
Old Jul 19, 2007 | 05:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
Spray that sucker with WD40 liberally and work it back it back and forth.
Old Jul 19, 2007 | 06:51 PM
66GTKFB's Avatar
66GTKFB
Didn't know WD-40 had healing properties. Remove and be more directional when spraying.
Jim
67LimeCoupe
Sep 30, 2015 04:46 PM
maestro1024
Sep 21, 2015 02:40 PM
Sep 8, 2015 11:50 AM
mustangchef
Sep 4, 2015 08:08 PM
SYNY5TER
Sep 2, 2015 01:35 AM
