Fan Shroud issues
Old Jul 20, 2007 | 02:37 PM
66GTKFB's Avatar
66GTKFB
Default RE: Fan Shroud issues
Just for reference, the 68 spacer length is 2 1/2 inches - mounting surface to mounting surface. Ford measures spacers to the top of the fan locator post which is listed at 2.95 inches.
Jim
Old Jul 20, 2007 | 02:51 PM
JMD's Avatar
JMD
ORIGINAL: 66GTKFB
Let me clarify Jeff's post - get the shroud as close to the radiator as you can, flush if possible. The fan should draw air thru the radiator, not from the space between the radiator and shroud. Fan spacing is another item.
Jim
I had always heard that the fan should fit about 1/3 to 1/2 of the way into the neck of the shroud for the the fan to work in the most efficient manner. Somthing about enhancement of the areodynamic properties of the fan....???
Old Jul 20, 2007 | 02:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: dano670
so the fan does not fit inside the shroud?
Your fan is exactly where it should be. Your only problem is that you are hitting in a corner of the shorud.Bend that corner a bit so the fan clears.
Old Jul 20, 2007 | 03:57 PM
groho's Avatar
groho
a rat-tail file works great to message the screw holes for extra movement, and yep, I have to make adjustment to mine also to clear hose clamps and fan.
Old Jul 20, 2007 | 04:26 PM
dano670's Avatar
dano670
okay, I will try to fix it this weekend. Thanks for the help.
Old Jul 25, 2007 | 06:41 PM
dano670's Avatar
dano670
The mustang is off at the exhaust shop, but before I dropped it off there I measured the fan. It is a 5 bladed aluminum type. I measured it to be 17 and 3/4 inches. I measured from tip to tip of the blades that were farthest apart (which is difficult on an odd numbered blade). The only info I found was that in one of my catalogs, it said 17 inch diameterfor the fan. Can anyone measure their fan for me? I just want to confirm I have the wrong one before I buy a new one. 65/66 w/289.
Thanks
Dan
Old Jul 25, 2007 | 07:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
From the center to tip is exactly 17".
Old Jul 25, 2007 | 07:09 PM
dano670's Avatar
dano670
That would make it a 34" fan, a little big to fit in the engine compartment.
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
Sep 25, 2015 09:06 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
2016PP
Sep 23, 2015 09:51 AM
