Pulstar Plugs
Old Jul 22, 2007 | 03:51 PM
shikoz's Avatar
shikoz
Default Pulstar Plugs
Has any one used these plugs? They don't have an application for my 1966 Mustang via internet but I'm sure they have something for 289s. The research sounds interesting and promising.
http://www.pulstarplug.com/index.html
Old Jul 22, 2007 | 04:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Pulstar Plugs
Interesting. Order some, put them in then get back to us with how many of your pistons wound up with holes in them.
Old Jul 22, 2007 | 04:34 PM
GypsyR's Avatar
GypsyR
Hmmm, interesting. Capacitive Discharge Ignition, in a new way. The "circuit" inside the plug is pretty much just a capacitor apparently. Assuming so I would say the ignition works much as they say. Sort of similar to an older CDI ignition. A decent explanation of CDI here-http://www.vw-resource.com/cdi.html.
$25 a plug? I dunno about that. For the same $200 you could get a proven, though more traditional CDI ignition such as an MSD 6A like here-http://www.modacar.com/products/Ford/Mustang/MODAIGC.
Traditionally the enemy of about all electronics is heat. Not surehow longa capacitor can live inside a spark plug. It would have to live a pretty long time and save mor ethan a little gas to recoup the $200 investment. Perhaps they really are that good and worth having. I'm quite willing to wait and let others find out first. I remember when Splitfire plugs were all the rage, right up until they were sued after proven to be smoke and mirrors. Ifthese CD plugscatch on I expect the price will drop to something more reasonable. At that point I will be quite interested. At least wait until somebody runs a set on a dyno before and after test.
Old Jul 22, 2007 | 04:43 PM
GypsyR's Avatar
GypsyR
Youthink that "spark plugs" are what burn holes in pistons?
Old Jul 22, 2007 | 05:35 PM
66GTKFB's Avatar
66GTKFB
What else creates heat in a cylinder? If you are too lean - heat. If you are too advanced - heat. Put in a $25 spark plug and with a bit of too little gas and bit too much advance - POOF.
Jim
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
