question on a 351C
Old Jul 22, 2007 | 06:52 PM
shr's Avatar
shr
Default question on a 351C
Well I bought a 1972 mustang convertable, it is in good shape but was sold without a running engine, they guy said that the motor is a 351C H.O. out of another car becasue the orginal one broke. I have pulled the plugs and ran a compression test and it has 160-167 psi on all cylinders so it seems healthy. Does anyone have a link or know where i can find engine #'s to identifiy the engine? Thanks Scott
Old Jul 22, 2007 | 06:53 PM
shr's Avatar
shr
Default RE: question on a 351C
heres a pic of the car....
[IMG]local://upfiles/39442/F2198273856F4BCF98B50B3C0C474CF6.jpg[/IMG]
Old Jul 22, 2007 | 11:54 PM
boss_dude_429's Avatar
boss_dude_429
look on the coil and see if the original engine tag is still there, if it's not then check intake there should be a part number, and get me those numbers and i can look through my bookes a find the codes to confirm
Old Jul 23, 2007 | 07:51 AM
shr's Avatar
shr
ok i will do that tonight, my only hope is the tag because the intake is a holley dominator
Old Jul 23, 2007 | 09:08 AM
andrewmp6's Avatar
andrewmp6
heres a link http://www.wrljet.com/fordv8/idtag.html
Old Jul 23, 2007 | 11:27 AM
RSRXION's Avatar
RSRXION
What marking is on the corner of the head ? At each end of the cylinder head, just at the corners of the valve covers, you'll see a number 2 , a number 4, OR , God forbid... nothing at all. The 2 is a 2 barrel head , the 4 is a 4 barrel and the blank spot is indicative of a 351/400 head. Cross everything you've got and pray for 4's. With respect to the block, what's the casting number on the side of the block ? You'll typically find it cast onto the exterior surface behind the starter. Lastly, the VIN pad is on the top of the block facing the firewall. With the use of a mirror you'll be able to read the VIN of the original car the engine came from. That should also prove to be most helpful.
This info should get you a nice start on ID'ing the engine. Good luck, Dean
mustangheaven
Jan 3, 2016 11:20 AM
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
