Iron Headed 306 Build
Old Jul 26, 2007 | 10:36 PM
sixty5mustang289's Avatar
sixty5mustang289
Default Iron Headed 306 Build
Alright, I have searched for hours on the net without any success, so I'm just going to ask on here and hope I can get an answer. I am in the process of building a 302 with a .030" overbore and ported/polished 351W heads with around a 10.5:1 compression ratio. A Comp hydraulic flat tappet camshaft with .534"/.534" lift and 244/244 duration at .050" lift.will be used. Do any of you have any experience or knowledge of what kind of power this engine will be capable of producing, given that all of the other necessary modifactions for an engine of this caliber are performed.
Old Jul 26, 2007 | 11:06 PM
67mustang302's Avatar
67mustang302
Default RE: Iron Headed 306 Build
That's gonna depend on heads and induction/exhaust. If all's good it should be able to easily put out 375-400hp though,maybe more. If the heads weren't done well it may not run well. It's hard to tell you when you have ported/polished heads, that doesn't really say anything about how they perform
Old Jul 26, 2007 | 11:21 PM
middiepride's Avatar
middiepride
ORIGINAL: 67mustang302
i dont see that much or more comin out of a 302 unless you have a much better prt job im expecting.
it can happen but i dont see it as much. im thinking like 325 ish at the flywheel
Old Jul 26, 2007 | 11:26 PM
valley firearms's Avatar
valley firearms
That sound a little too generous in the horsepower department for that 306. I'd say in the low 300's, maybe a tad more. Need more details. Valve size, intake used, carb, headers, gears????
[align=left] [/align]
Old Jul 26, 2007 | 11:35 PM
67mustang302
My 307 is putting out around 350 at the flywheel(calculated based on trap speed and vehicle weight)through a 570cfm carb at less than 6krpm with no type of cold air induction. That engine has a bigger cam, but it is gonna come down to the heads. If the heads were done very well it could easily put out over 400hp, if the headswere done likecrap, it may put out less than 300 and produce bumpkiss for torque. The heads can make or break an engine. But 10.5:1 static compression with a beefy cam can make a crapload of power with good heads and the induction to match
Old Jul 27, 2007 | 11:06 PM
67coupe's Avatar
67coupe
You will need pop top pistons to get near 10.5:1 with those heads. With flat tops more like 9:1.
Old Jul 27, 2007 | 11:14 PM
takeoutexodus's Avatar
takeoutexodus
for that kind of a mod . my bets are on no more than 330 or so .
Unless there are alot of other things you havent mentioned ...
we need more info ..
[sm=smiley23.gif]
Old Jul 27, 2007 | 11:17 PM
67mustang302
Really need info on the heads, primarily what they flow at and with what port/valve sizes
Old Jul 28, 2007 | 12:49 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Mine estimates around 400hp with a smaller cam, but 2 points more compression. Based on a 120mph trap speed in a 3300 pound car. It actually estimates more...but use the more conservative number.
Old Jul 28, 2007 | 10:56 AM
JMD's Avatar
JMD
ORIGINAL: sixty5mustang289
Compared to a similar build of a different brand engine that I know the HP produced, and then adjusted for displacement, I guestimate about 330 HP, with asomewhat mild but good performanceintake and exhaust. (medium mild? )
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Drastang
Sep 30, 2015 03:48 AM
