sheet metal challenge???
Old Jul 30, 2007 | 12:29 PM
groho's Avatar
groho
Default sheet metal challenge???
This is aimed at the guys/gals who've done sheet metal. All the mechanicals are done on the '66 coupe; brakes, susp, driveline, rear-end, motor, electrical. I'm at the point where I can gut the car, and start working on the body. I knowthe trunk floor & rear valance need to be R&R. I'm confident in my abilities, but have never done sheet metal. How difficult is it to replace panels?The plan looks straight forward: support the car, re-inforce panels to prevent buckling, drill out spot welds, etc, etc, test fit new panel. . .test fit again. . .and then test fit again. . .weld. I plan on picking up with welder, 140A gas (110VAC), and some junk doors to play with before I dive in. Any advise??? Lessons learned??
Old Jul 30, 2007 | 12:34 PM
JBradley500's Avatar
JBradley500
Default RE: sheet metal challenge???
If i were you i'd just buy new door shells and swap over all the internals to the doors if you are thinking about putting skins on.
Old Jul 30, 2007 | 12:49 PM
atomsk680's Avatar
atomsk680
after you cut out the old metal, testfit, trim new panel, test fit, trim, ect, i drilled holes around the new panel and filled in the holes with spotwelds to hold it up
http://www.cardomain.com/ride/2376813/4
theres some pics of before and after
Old Jul 30, 2007 | 01:54 PM
66GTKFB's Avatar
66GTKFB
Practice weldingman, practice.
Jim
Old Jul 30, 2007 | 02:00 PM
jlg2002's Avatar
jlg2002
ORIGINAL: groho
Go to mustangs monthly and read the article on the trunk floor replacement. (July 2006) The rear valance is bolt on so not much of a job, just be careful when your tightening it up and practice your welding.
Old Jul 30, 2007 | 08:01 PM
Astrawn's Avatar
Astrawn
Don't try to start at one point and weld in a clockwise motion from start to finish. Tack weld a little go to the opposite andtack weld a little. If you don't the heat will warp the panel. Spot and fill, spot and fill. Its a slow process this is why it costs so much to have it done. My rear quater took a long Saturday just to get it welded in.
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 28, 2015 10:54 PM
mrappe
Sep 26, 2015 10:16 AM
