Another tire question, sorry guys
Old Jul 31, 2007 | 05:50 PM
bluovalguy's Avatar
bluovalguy
Default RE: Another tire question, sorry guys
I've got my fingers crossed that they will work. If not, having drums is not the end of the world I guess. Alot of people are still running 'em.
Old Jul 31, 2007 | 05:57 PM
shikoz's Avatar
shikoz
ORIGINAL: gothand
FWIW, disk brakes from the factory came with 14" wheels so the blanket statement that 15" wheels are needed is not always necessarily true. That said, I believe it is needed with the Granada swap. The Stainless Steel Brakes conversion is essentially a duplicate of the factory four piston setup and will work with 14" wheels.
FWIW, my brother's '66 vert has 14" repop styled steel wheels, SSBC brakes and 215/60-14" BFGs and fits without issue. Your wheels may need a little more negative offset if you are having clearance issues.
+1 I've got the SSBC disc swap with my stock 14' steel wheels w/ caps.
Old Jul 31, 2007 | 06:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: bluovalguy
I'm still runnin' 'em, but I almost T-boned an SUV a few months ago who came into my lane , and if I hadn't ditched Ol' Yeller, I would have had a big time bad front end wreck. The shoes just don't give you a straight line stop. The rear squirrels all around and throws your car into a spin when you really stomp on them.
Old Jul 31, 2007 | 06:49 PM
bluovalguy's Avatar
bluovalguy
ORIGINAL: shikoz
ORIGINAL: gothand
Mine will be parts from a Granada, not SSBC, so hopefully it will work out. Either way, I will have the parts and I can make the switch later on. Thanks much for all the help!!
drfister
May 3, 2018 10:38 PM
Soldier GT
Aug 12, 2015 03:46 PM
StangMuscle
Aug 12, 2015 07:27 AM
ccwebb
Aug 11, 2015 06:47 PM
mustangfan305
Aug 7, 2015 11:09 AM
