Mobil 1
Old Jul 31, 2007 | 08:55 PM
Dancin52's Avatar
Dancin52
Default Mobil 1
Has anyone had a problem with Mobil 1 leaking from the front of the oil pan? I'm currently replacing the pan gasket with a Perma dry plus by fel-pro. should I stay with Mobil 1 or go back to a regular oil like Castrol?
Old Jul 31, 2007 | 09:19 PM
JamesW's Avatar
JamesW
Default RE: Mobil 1
If you like Mobile 1...stay with it..you should be ok.
Old Aug 1, 2007 | 11:15 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Mobil 1
Oil leaks are the fault of the gasket/installer, not the oil. Sorry.
I always use a silicone sealant/adhesive for all oil gaskets (except the valve cover to head junction) for added security. None of my engines leak...at all.
Old Aug 2, 2007 | 08:44 AM
mikethebike's Avatar
mikethebike
Default RE: Mobil 1
You didn't say how many miles were on the engine. If the only oil that it ever saw was Castrol the gaskets should not have hardened and shrunk. That is the biggest problem with going to a synthetic oil after years of dino. The gaskets harden, shrink but are sealed by the deposits from the dino (NOT CASTROL) and then when you start using Mobil-1 the deposits are cleaned off and the oil finds it way out. Otherwise I'll agree with the post about the gasket being bad.
American Iron motorcycle magazine did a series of articles back in 2000 ane even got the Mobil engineer who led the project to write most of the article. The points I remember were that moly-dendum is especially bad for your seals/gaskets and unless you are seeing very extreme temp. changes such as -0 or 110+ you don't need to spend the extra money.
Soaring may now quote ALL the numbers he wants....the 1st amendment is still here....but when there are numerous engines using Castrol GT/X that have more than 500,000 documented miles and no ring, bearing, valve, or timing chain failures I have to believe GT/X is plenty good enough.
My 1977 XLCH has seen nothing but GT/X since I had to do a top-end at 18,000 due to an exhaust valve sticking...cause by oil deposits from using 60 w H-D oil of the era. Warner Riley of Lakeshore H-D told me that year to start using GT/X 20-50 and I would never stick another valve and he was correct. Not only that but when I did another top end at 96,000 the reason was from contaminates that a K&N air filter allowed in...not from the oil and this is a cast-iron Sporty that runs an oil temp of 250-275.
But you can do what you want...it is afterall, your money.
Urambo Tauro
Oil and Oil Related Topics
Dec 11, 2017 07:16 AM
BeatnikFink
Oct 1, 2015 08:00 PM
algregory
Sep 6, 2015 05:52 PM
BCATL79
3.7L V6 Technical Discussions
Aug 13, 2015 07:41 PM
don_w
May 4, 2005 09:20 PM
