69 I6 has five lugs
Old Aug 1, 2007 | 12:12 AM
05SDI's Avatar
05SDI
Default 69 I6 has five lugs
I just ran the VIN # on a 69 grande and it comes up I6 even though the car has 5 lugs (F&R) and ford 9" rear end. I can not make out the door tag as it is like a sticker NOT like every other classic Mustang I have had that has had a metal tag with body, color, trim, date, DSO, axle, trans. This car has a sticker on the driver doorwith this infobut being 38 years old it can't be made out. Is there any other place that his info could be found?
The car currently has a 302 and 4 speed that appears to have been in the car a very long time.
Old Aug 1, 2007 | 02:13 AM
andrewmp6's Avatar
andrewmp6
Default RE: 69 I6 has five lugs
its a used car who knows whats its been done to it over the years. that door tag is the only place i know of that has that info. could have started life as a inline6 car got everything changed out later on. unless you want to track down every owner of it id just ignore it and enjoy the car.my dad use to have a 71 fastback that was a inline 6 but the car was a 5 lug.my 68 started life as a inline 6 car when i got it. it had a 302 2 barrel c4 and a 8 inch rear.
Old Aug 1, 2007 | 06:33 AM
05SDI's Avatar
05SDI
Thanks andrew, butI have no desire to track down each owner...
Iguess mylong winded question is; were I6 cars 4 lug in 1969?
Old Aug 1, 2007 | 08:11 AM
andrewmp6's Avatar
andrewmp6
im not sure as far i know all inline 6 cars where a 4 lug since they used the 7.5 rear end in sted of a 8 inch or 9.since yours is a 9 inch someone put it in there. only mustangs with a 9 inch are big block or early gt ones.
Old Aug 1, 2007 | 08:31 AM
boogerschnot's Avatar
boogerschnot
The 69's all had 5 lugs.. At least Im pretty sure they did,, They also came with the heavier suspension, so no need for changes when doing v-8 swaps.. Correct me if im wrong..
Old Aug 1, 2007 | 10:50 AM
JMD's Avatar
JMD
ORIGINAL: boogerschnot
Nope,,, I think you are right, I think that 67 up cars used 5 lug and common suspension with the V8, the rear axle should be a 7.somthing, so it wont last long behind a V-8 unless it is babied.... I think the springs are a little different also.
Old Aug 1, 2007 | 01:56 PM
scouttrooper's Avatar
scouttrooper
I'm sure you've considered this, but if the tag on the door is the only place you could obtain this information, and the door was swapped... there may not be much that's represented correctly. People who aren't in the biz, (hobbiest like me), may not have the wherewithall to have made sure a door tag stayed with the original car. I doubt it would have even occured to me. Just a thought. Best of luck,
Old Aug 1, 2007 | 11:09 PM
Colorado_Mustang's Avatar
Colorado_Mustang
I know '71-'73 all had 5-lug suspensions with at least an 8" rear. I believe this started in '71, but it wouldn't surprise me if it did start in '69.
Old Aug 1, 2007 | 11:31 PM
66GTKFB's Avatar
66GTKFB
To find out all the assembly line info get a Marti report from http://www.martiauto.com/
Jim
Oct 7, 2015 07:02 PM
DCole24
Sep 11, 2015 10:50 AM
inyadreems
Aug 21, 2015 09:10 AM
Fast-Hands
Aug 19, 2015 06:54 AM
cody
Oct 30, 2003 06:49 PM
