66 Leaf Spring Questions
Old Aug 1, 2007 | 12:13 PM
LPlum's Avatar
LPlum
Default 66 Leaf Spring Questions
Several years back I replaced the rear leaf springs. I have some questions. The rear suspension has a squeaks that I feel ties into the leafs. Should of the springs, bolts, or bushings of been lubed? What are the torque specifications for the U bolts? It seems like I just kept tightening and tightening them, I'm sure they are now stretched. I have sinced ordered new U bolts. If I jack up the rear end, which should take the pressure off the springs. Then change one U bolt at a time. Will this work? Or is there a better procedure?
Thanks Lowell
Old Aug 1, 2007 | 01:44 PM
VintageBlue's Avatar
VintageBlue
Default RE: 66 Leaf Spring Questions
I think to replace the u-bolts, you don't need to jack the car up. If you need to for access, put it on jack stands, then jack up the rear axle to take the pressure off of the u-bolts. Then remove them.
Old Aug 1, 2007 | 01:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
Squeaks from the rear springs usually come from the shackles. Put the rear in the air and loosen the shackle bolts then put the car back on the ground and tighten the shackle bolts back up.
Old Aug 1, 2007 | 02:10 PM
jlg2002's Avatar
jlg2002
ORIGINAL: Soaring
To go al ittle further with Soaring's resposne:
or dirt, crud, rust, from between the leaves. or from bad pads or no pads
Old Aug 1, 2007 | 02:34 PM
Soaring's Avatar
Soaring
I ♥ Acer
The torque for the U bolt nuts is 35-50 ft. lbs.
Old Aug 1, 2007 | 02:46 PM
66GTKFB's Avatar
66GTKFB
The Ford recomended torque on the u-bolts is 30 to 45 ft-lbs.
Jim
Old Aug 1, 2007 | 06:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
Ok, let's flip a coin. Do we go with the Haynes Ford V8 Mustang manual, or do we go with the un-mentioned Ford recommended torque specs Jim mentions? It doesn't really matter. It is only a ballpark figure.
Old Aug 1, 2007 | 06:23 PM
66GTKFB's Avatar
66GTKFB
Tighten the nut until is starts to spin free, then back off 3/4 turn.
My reference is the '1966 Comet, Falcon, Fairlane and Mustang Shop Manual' Group 3, page 3-50, Fig. 2, Ref. No. 4. Is that sufficient to find the info?
Jim
Old Aug 1, 2007 | 06:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
At least the information is from a manual and not your memory.
Old Aug 1, 2007 | 06:54 PM
66GTKFB's Avatar
66GTKFB
Burgundy induced memory right now. I'm all done bead blasting hardware for the day so it's 'Happy Hour'.
Jim
PullTab
Oct 30, 2015 08:46 AM
9550
Oct 26, 2015 05:01 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 1, 2015 08:16 PM
