cleaning your engine
Old Aug 2, 2007 | 12:35 AM
xian67's Avatar
xian67
Default cleaning your engine
what are some good ways to clean your engine and all the other stuff under the hood?
Old Aug 2, 2007 | 12:45 AM
andrewmp6's Avatar
andrewmp6
Default RE: cleaning your engine
i put a plastic bag over the carb and dizzy and use a power washer just dont do it too much will make the plugs rust.are you going for a first time cleaning or shining it up for a carshow.
Old Aug 2, 2007 | 12:50 AM
xian67's Avatar
xian67
well its just dirty with dirt oil and other stuff. i just want it to look nice.
idk if its been washed before but this is going to be the first time i wash it since ive bought it.
Ive herd steam cleaning it works or something like that.
Old Aug 2, 2007 | 01:01 AM
RedMachAndOrangeFox's Avatar
RedMachAndOrangeFox
Power wash with simple green and then go back round with a brush and rinse
Old Aug 2, 2007 | 01:12 AM
groho's Avatar
groho
Your gonna think I'm nuts!Sure the auto degreasers work, but if you got some subborn stuff, I found a degreaser at HomeDepot, made by ChemDry, called Stain Extinguisher, oil and grease remover, with the carpet spot removers,in the cleaning section with mops and brooms. Used it on the bottom of my '66 after I bought it. Was stunned at the results! Took it all the way down to the factory paint, and never damaged the primer. Asoft brissle brush on the stubborn spots helps. I've used everything in the past, and this was absolutely the best andeasiest! Spray it on, let it soak in, and wipe it down with a rag.
Old Aug 2, 2007 | 01:20 AM
xian67's Avatar
xian67
would it be this?
http://www.advancedchemdry.co.uk/sta...-20oz-p-1.html
edit: and if i wanted show quality how would you recommend cleaning it?
Old Aug 2, 2007 | 01:56 AM
groho's Avatar
groho
nope. close but not the same product, at the bottom of the same webpage is. .this appears to be right, but in a different packaging.
Old Aug 2, 2007 | 03:34 AM
xian67's Avatar
xian67
so that will work for my engine and all the stuff under the hood right?
Old Aug 2, 2007 | 10:42 AM
ndnboy's Avatar
ndnboy
wire brush for the big stuff and degreaser and rags for the rest, it worked for me....
Old Aug 2, 2007 | 11:10 AM
66GTKFB's Avatar
66GTKFB
There is another Home Depot (and others) product called 'Krud Kutter' found in the paint section. It's a paint remover too so be careful. I used it on a Top Loader and it cleaned up nice. I'll give the 'Chem-Dry' stuff a try. Always looking for something new. Another product to try is 'Eazy-Off' oven cleaner. My ex-boss used that on his 39 Lincoln Zepher project.
Jim
