Where does reverse go?
Old Aug 5, 2007 | 03:51 PM
71mopar383's Avatar
71mopar383
Default Where does reverse go?
Y do I loose reverse when my c4 gets up to temp? Cold goes right in goes around the block you have to rev it to 2 grand for rev another round no rev.
Old Aug 5, 2007 | 03:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Where does reverse go?
As I understand it, reverse on a C4 requires more pressure to operate than your forward gears. Check you fluid level and if it is OK, I would suspicion the pressure pump as not generating enough pressure to tighten the reverse bands when the fluid thins down.
Old Aug 5, 2007 | 04:40 PM
71mopar383's Avatar
71mopar383
Could the rear band be out of adj
Old Aug 5, 2007 | 04:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Could be, but by your description, it sounds like a pressure pump problem. I have an article about how to tighten your bands in the FAQ up toop under transmissions. You might give that a shot. Won't hurt anything.
Old Aug 6, 2007 | 06:41 AM
71mopar383's Avatar
71mopar383
I think the rear band was out of adj it seems better now on stands. Going to drive it today.
Old Aug 6, 2007 | 10:37 PM
Colorado_Mustang's Avatar
Colorado_Mustang
The band for reverse is shared with low (1st). As Glen mentioned, check the fluid and all the adjustments. Wouldn't be a bad idea to change the filter/fluid as well.
If you do need a rebuild, don't forget the external trans filter and synthetic fluid. An extra cooler wouldn't be bad, either. Autos don't like running anywhere near the temperature of the engine.
Old Aug 7, 2007 | 06:40 AM
71mopar383's Avatar
71mopar383
Well here is the deal...Its a new TCI but it was installed after the 1 yr warr was up..took it to the muffler shop yesterday went right into rev coming out of the garage. Had 1st 2nd no 3rd, while it was up in the air adj the vac mod. Wouldnt go into rev had to push it off the rack and still no 3rd so I guess Ill be calling tci
Gene K
Oct 21, 2015 11:37 PM
foxdude
Sep 24, 2015 08:45 PM
maestro1024
Sep 21, 2015 02:40 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
