No Juice
Old Aug 6, 2007 | 12:56 PM
66pony21's Avatar
66pony21
Default No Juice
I got the engine rebuilt and put back in and all my electrical hooked up on Saturday but when I turned the key I had nothing. There is no power at all the interior lights don't even light up. I checked all my connections and everything looks good. I even have a new battery. What could I be missing?
Old Aug 6, 2007 | 01:17 PM
67mustang302's Avatar
67mustang302
Default RE: No Juice
Try checking your ground
Old Aug 6, 2007 | 01:46 PM
66GTKFB's Avatar
66GTKFB
There is an engine to firewall ground near the heater blower required as well.
Jim
Old Aug 6, 2007 | 02:11 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
When you check the grounds make sure there's no paint between the cable/strap and frame/block, and, I apologize in advance for stating the obvious, make sure everything is tight.
Old Aug 6, 2007 | 02:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Check for voltage at the fuse box. No votage? Then the trouble lies between the fuse box and the solenoid. Got voltage? Then go back and check every wire between the fuse box and ignition switch until you get voltage at the ignition switch.
Old Aug 6, 2007 | 02:55 PM
jlg2002's Avatar
jlg2002
In addition to all of the other fine answers provided, check that the the firewall connector outboard of the brake booster/master cylinder is not loose.
Old Aug 6, 2007 | 02:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: jlg2002
Yeah, if there is no juice to the fuse box, that is about the first thing that should be checked.
Nurdyguy
Jan 20, 2025 04:38 PM
jwog666
Dec 27, 2021 08:09 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
beezy
Nov 10, 2004 04:14 PM
Big5.0.13.7sec.
Nov 4, 2004 02:02 AM
