Cams for a juiced motor
After I do headers and some suspension I am considering a 100 shot of juice. WHat sort of cams would I want? Just some stage 1 or 2 N/A cams sicne I would be driving the car off the juice more often than being on it? I hear they do make nitrious cams but they are more for hardcore drag cars right?
RE: Cams for a juiced motor
You should be fine with the N/A cams, a nitrous cam usually makes the car run like **** off the N2o.
If you are thinking VT the only reason you should pick between the 2 cams is weither or not you want to replace the valvesprings while your at it. If you do replace em get the stage 2s.
jwog666
12-27-2021 08:09 PM
