Roll Barz!
Old Aug 13, 2007 | 01:22 AM
EmperorOfChicken's Avatar
EmperorOfChicken
Default RE: Roll Barz!
sure ill take some for ya tomarrow.
Old Aug 13, 2007 | 02:41 AM
gothand's Avatar
gothand
What are you guys doing that you need roll cages? I have a custom fabbed 6 point cage in my Jeep but I'm doing things with it that put me at risk. Short of racing, why the rollcage in a classic? Not bagging, just curious.
Old Aug 13, 2007 | 06:32 AM
Norm Peterson's Avatar
Norm Peterson
I'd put it a bit more strongly - a cage represents an additional hazard to any unhelmeted head that's in the car. In a design-basis sort of incident where the cage ends up doing the job it's supposedly there for, there's a net gain for having it. But that's not necessarily true for the more run of the mill sudden stops, swerves, bumpsand minorcollisions that can still toss a passenger who's been caught off-guard around more than you might expect - even with seat belts in use.
If you must have it, get it installed as far up against the OE roof structure and as far away from properly seated heads as it can be put. Weld quality is a huge deal, so if you don't have a whole lot of experience with the process, get it professionally done. If any sort of competition requiring one is expected, make sure that the tubing OD and wall thickness meets sanctioning body requirements.
Norm
Old Aug 13, 2007 | 07:01 AM
andrewmp6's Avatar
andrewmp6
use this http://www.mustangsplus.com/Merchant...uct_Code=04202 and subframe connectors car will be nice and stiff i only have a cage for drag racing if i didnt drag race i wouldnt have a cage.theres a few ways to stiffen up a car with out a cage.
Old Aug 13, 2007 | 09:02 AM
mikethebike's Avatar
mikethebike
ORIGINAL: Norm Peterson
I'd put it a bit more strongly - a cage represents an additional hazard to any unhelmeted head that's in the car. In a design-basis sort of incident where the cage ends up doing the job it's supposedly there for, there's a net gain for having it. But that's not necessarily true for the more run of the mill sudden stops, swerves, bumps and minor collisions that can still toss a passenger who's been caught off-guard around more than you might expect - even with seat belts in use.
Norm
Even if the guy knows it coming the g's will overcome muscle strength. Everytime. Your 2nd paragraph is just 1 more reason to have it custom built by a shopp with lots of experience.
Old Aug 13, 2007 | 10:41 AM
JPaikos's Avatar
JPaikos
I had the cage installed for this.
N.A.S.A. Pro Racing
Old Aug 13, 2007 | 02:24 PM
ShAkE N BaKe!!'s Avatar
ShAkE N BaKe!!
i want to get it for autocrossing. Just in case I loose it on a turn and flip.
Old Aug 13, 2007 | 03:07 PM
JPaikos's Avatar
JPaikos
There's a danger of flipping in cone *******....I mean auto crossing? [sm=smiley36.gif]
Old Aug 13, 2007 | 03:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
Is there a roll cage that can be bolted in easily just before you go auto crossing? If not, then you need to make a choice. Either put the cage in and only use the car for autocrossing, or forget about it and drive it as a classic mustang.
Old Aug 13, 2007 | 03:35 PM
ShAkE N BaKe!!
I can do both!
