Roll Barz!
Old Aug 12, 2007 | 02:14 AM
ShAkE N BaKe!!'s Avatar
ShAkE N BaKe!!
Default Roll Barz!
After Im done with my brakes Im thinkin about adding a roll bar to my 65 coupe. I was wondering if you guys can post pics of your set-ups. Thanks!
Old Aug 12, 2007 | 02:50 AM
390bigblock's Avatar
390bigblock
Default RE: Roll Barz!
i had a roll cage wen i first got my car but i took it out ill try to find sum pics but it was mounted by the driver and passenger and in the back seat and a bar in between for the seat belts and then in the trunk 2
Old Aug 12, 2007 | 06:29 AM
67 evil eleanor's Avatar
67 evil eleanor
There are a couple of choices. The good ole Shelby type welds or bolts to the floor then attaches to the inside upper corners. Unless its an R modle type, its a single bar (no crossmember). It allows access to the back seats and is pretty much out of the way. The other mounts in multiple locations. These offer much better protection in case of a rollover and are normally required for racing. Another good point is, ifa 6 point if done correctly, itwill also relieve a lot of the unibody flex, similar to sub-frame connectors.You will notice an immediate difference when you drive. One disadvantage is, the 6 points usually run on the sides of the dash and into the floor board. This hinders entering and exiting the vehicle, more so if you have big feet. I think either is a good safety investment. I would also install shoulder harnesses if you do a 6 point.
http://i140.photobucket.com/albums/r...r/DSC00424.jpg
Old Aug 12, 2007 | 11:48 AM
mikethebike's Avatar
mikethebike
Experience talking here.....go to a race shop and have them build one for your car. It will be easier, it will be better (YOU can chose tube diameter and wall thickness), it will be safer, it most likely will be less expensive. It will fit better.
Old Aug 12, 2007 | 03:26 PM
JPaikos's Avatar
JPaikos
Check AutoPower. There located in San Diego, CA
http://www.autopowerindustries.com/
They did a custom install in my '66 Fastback
[IMG]local://upfiles/2777/4FE02F132DD5475F99BDFD011BCD2942.jpg[/IMG]
[IMG]local://upfiles/2777/DF885D990C714AC39E191EE340D0459B.jpg[/IMG]
Old Aug 12, 2007 | 03:31 PM
EmperorOfChicken's Avatar
EmperorOfChicken
i just have a bar...no cage. i need a cross bar so i can mount my harnesses at the right height, let me find a picture:
you have to look at the edges of the icture but you can see it, my shoulder harnesses are mounted from it from up top, it follows the roof line. i dont wear them and i wont until i get teh cross bar [8D]
Old Aug 12, 2007 | 04:40 PM
ShAkE N BaKe!!
Did this on PAINT,
but just to give you guys an idea of what I want. How much do you think something like this would cost?
Old Aug 12, 2007 | 05:26 PM
dcohen's Avatar
dcohen
[sm=redx.gif]
Old Aug 12, 2007 | 06:06 PM
ShAkE N BaKe!!
let me know if you still cant see it[>:]
Old Aug 12, 2007 | 10:54 PM
69stangcoupe's Avatar
69stangcoupe
hey emperorofchicken can you get some better pics of that roll bar?
