289 heads
Old Aug 13, 2007 | 07:35 AM
fenderleo's Avatar
fenderleo
Default 289 heads
are the cyl heads ofa 289 2 bbl and a 289 4 bbl the same? if i install a 4bbl intake and carb on a 2 bbl engine, will it perform like a factory 4 bbl?
Old Aug 13, 2007 | 08:47 AM
mikethebike's Avatar
mikethebike
Default RE: 289 heads
The porting was the same but I think the 4-barrel had a smaller combustion chamber. Performance will depend on how well you tune it.
Old Aug 13, 2007 | 08:49 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, the A code heads have a slightly smaller combustion chamber. Putting a 4 barrel carb on a C code engine won't give you much benefit.
Old Aug 13, 2007 | 09:34 AM
my77stang's Avatar
my77stang
Old Aug 13, 2007 | 10:21 AM
66GTKFB's Avatar
66GTKFB
Bull-puckey. There is no difference between two barrel and four barrel heads on a 289 CID engine. Compression ratios were determined by piston height, combustion chambers were the same, valves were the same, the heads were identical. Now, there were different combustion chambers for different years, but those heads were used interchangably for that years models.
Jim
Old Aug 13, 2007 | 10:46 AM
EmperorOfChicken's Avatar
EmperorOfChicken
if one was to be looking to buy some after market heads, how many CCs should they look for for a mild-moderately modded 289? (moderate cam, intake, carb, gears/posi?) i was lookin at some AFR heads and im not sure which CC to look for[:@] 165, 185, 205?
Old Aug 13, 2007 | 11:22 AM
my77stang's Avatar
my77stang
165's, but canfield 170's or the smaller RHS heads would be better IMO.
Norm Peterson's Avatar
Norm Peterson
165 will be all you need in a 289. 185's would be better off in a similarly built 331 - 347, and 205's way too much for the little motor (can you say "lazy flow"?).
Norm
(who has AFR 190's in a mild/moderate 350 SBC, BTW)
Old Aug 13, 2007 | 11:23 AM
EmperorOfChicken
link me up baby!
Old Aug 13, 2007 | 11:43 AM
my77stang's Avatar
my77stang
http://www.canfieldheads.com/sbf_standard_intake.htm (170cc runners)
<~~~ owned by comp cams btw (180cc runners)
http://www.compperformancegroupstore...egory_Code=SBF
and of course there is always the gt40p's from tristatecylinderhead for 600 bucks a pair which would flow excellent for your motor without being too big.
