mini spool?
Old Aug 14, 2007 | 12:42 AM
  #21
andrewmp6's Avatar
andrewmp6
Default RE: mini spool?
they are right a spool is never a good idea on a street car.
Old Aug 14, 2007 | 09:16 AM
  #22
muggsy's Avatar
muggsy
Is a Trac-loc an LSD or spool-like? I know that a Detroit Locker is not an LSD....
Old Aug 14, 2007 | 12:59 PM
  #23
jspagna1's Avatar
jspagna1
ORIGINAL: EmperorOfChicken
yep 3.80s in a c4. maybe yall can tell me "i told ya so" later when i start whining about them, but until then SHOVE IT thanks for the advice, LSD unit it is. i dont wanan die[:@]
I'll tell you now: I told you so. Too much gear. The most I would go is 3.55's. I almost went with 3.73's and I am glad I didn't.
[/align][/align]
Old Aug 14, 2007 | 05:25 PM
  #24
Aussie66Fastback's Avatar
Aussie66Fastback
ORIGINAL: muggsy
spool makes both wheels drive all the time...that's why they are not so good on the street because when you turn into the pub car park, the outside wheel wants to turn faster than the inside wheel so they sound like they are trying to rip tyres off the rim. But when you want both wheels to put power to the road (ie at the strip) they are great.
Trac-loc is a LSD using clutch packs to put power to the wheel with the most traction
Lockers are in between - they either disengage for corners (67M302's Powermax) or engage (Detroit Locker works this way i think) when traction is lost to one wheel - but tend to do so more violently.
Torsens and Truetracs are LSD, but work with gears instead of clutches. Stronger and more reliable - no slipping.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
mungodrums
Sep 29, 2015 09:18 PM
Sep 8, 2015 06:25 PM
iamgobono
Sep 3, 2015 12:37 PM
