mini spool?
Old Aug 13, 2007 | 11:14 AM
EmperorOfChicken's Avatar
EmperorOfChicken
Default mini spool?
can some one explain a mini spool to me? i was lookin for some gears and a posi/LSD unit and was surfin jegs and came across a "mini spool". ive decided to go with 3.80s (dont try to talk me out of it im craaaaaazy!!) but this peg leg has seen its days, and they are on there way out. englighten me gentlemen!
Old Aug 13, 2007 | 11:40 AM
gothand's Avatar
gothand
Default RE: mini spool?
A mini-spool replaces the spider gears in the diff and a full spool replaces the diff. Both will positively lock your two axles together (i.e. squealing tires, crappy handling, dangerous in wet conditions ... DON'T DO IT!!!).
Old Aug 13, 2007 | 11:51 AM
Norm Peterson's Avatar
Norm Peterson
A peg-leg is better at the dragstrip than a spool is in all-around driving.
I hope you're considering an overdrive to go with those3.80's (I haven't gone back to check for any recent tranny-related threads yet, but I think there might have been one). When gas was $0.219 instead of $3.219 and there weren't as many Interstate highways, this didn't seem to matter quite as much.
Norm
Old Aug 13, 2007 | 11:54 AM
EmperorOfChicken
nope im using my c4 non od tranny. i dont do much highway driving in the 65, and in a few weeks i will be doing almost none with it. all side streets and what not (speed limits of no more than 50) so i should be alright.
Old Aug 13, 2007 | 01:11 PM
73 Sportroof's Avatar
73 Sportroof
I went with 3.89 gears with a dura grip dif from Yukon Gear behind a C6.
60 mph = 3000rpm
I drive on the highway every day, but I don't take the freeway.
I'm still trying to get the speedometer correct, but it looks like I am getting 15 mpg.
The rear end chatters a little on corners, but not bad. Locks up good.
Old Aug 13, 2007 | 01:21 PM
EmperorOfChicken
hey 73 do you have an 8"?
67mustang302's Avatar
67mustang302
If it's a street driven car you might wanna consider a high bias carbon friction clutch pack LSD, or a locker such as a Detroit or a Richmond Powertrax etc. I have a Powertrax in mine, locks the axles when you go straight or get on it, opens to full differentiation when you turn. It completely replaces the differential assembly(side and spider gears etc). A mini or full spool will be a pain in regular street driving, dragging tires around the corner, chirping and shuddering in parking lots etc, also will accelerate tire wear
Old Aug 13, 2007 | 01:26 PM
EmperorOfChicken
okay, thanks guys that makes it much more clear to me, i get it. got any links to where i can find some of those lockers 67? thanks
Old Aug 13, 2007 | 01:39 PM
Norm Peterson
Understand that any locker wants to either coast around turns or take them with the tail drifting slightly under enough throttle to put it out there.
They do not like tight turns under normal street driving levels of throttle, so you have to drive them a bit differently than you would a pegleg or limited slip of any sort. Instead of "in slow, out faster as the throttle is going down", you need to think "in slightly faster to make up for coast-down slowing, wait until you're straight, then power".
Norm
Old Aug 13, 2007 | 01:40 PM
67mustang302
http://www.jegs.com/webapp/wcs/store...44476_-1_10153
http://store.summitracing.com/egnsea...115+4294908331
The Jegs link is for the Powertrax and the Summit link has all the spools/lockers/LSDs they carry, just select your axle size, 8, 9, 8.8 etc and the locker or LSD you wanna look at
