351?
Old Aug 17, 2007 | 05:59 PM
  #21
JMD's Avatar
JMD
Default RE: 351?
http://store.summitracing.com/egnsea...115+4294860737
http://store.summitracing.com/egnsea...115+4294840125
Here is a start,,, junkyard would be cheapest, unless a member here might have some stock pulleys they are not using,,,,,
Old Aug 17, 2007 | 06:29 PM
  #22
crazyhorse's Avatar
crazyhorse
Default RE: 351?
go with some good aluminum heads- they not only flow better,but lighter too. good luck.
Old Aug 17, 2007 | 09:17 PM
  #23
ShAkE N BaKe!!'s Avatar
ShAkE N BaKe!!
Default RE: 351?
Can I use my power steering on the 351?
Old Aug 17, 2007 | 10:20 PM
  #24
JMD's Avatar
JMD
Default RE: 351?
ORIGINAL: 67mustang302
And GM F bodies, good GAWD......ever tried to stick an engine in one of those things? It's like trying to shove a hippopotomus into a tuna can! I think GM built the cars around the engines with the F bodies.
My brother-in-law has his F-Body parked in my driveway,,,, he is changing his engine,,,, it is a true bit*h to work on,,,,, I would never hot rod one of those because they ar soooo miserable to work on...When working on these a person soon learns that something is in the way of everything.... without exception...
Give me a 351 64-66 Mustang any day....
  #25
JMD's Avatar
JMD
Default RE: 351?
ORIGINAL: ShAkE N BaKe!!
yes
Old Aug 17, 2007 | 11:04 PM
  #26
jcomp's Avatar
jcomp
Default RE: 351?
ORIGINAL: JMD
My brother-in-law has his F-Body parked in my driveway,,,, he is changing his engine,,,, it is a true bit*h to work on,,,,, I would never hot rod one of those because they ar soooo miserable to work on... When working on these a person soon learns that something is in the way of everything.... without exception...
I wasn't going to say anything... but here is a GM F-Body with a Pontiac 400, which has the same external dimensions as a Pontiac 455. It is also roughly equivalent in size to most other manufacturers' "big blocks".
Looks like plenty of room to me.
Old Aug 17, 2007 | 11:20 PM
  #27
ShAkE N BaKe!!
Default RE: 351?
If Im going to use alternator, and power steering, all I need is a 2 groove crank pulley right?.
Old Aug 17, 2007 | 11:36 PM
  #28
jcomp's Avatar
jcomp
Default RE: 351?
Here's what the accessories looked like on my 69 351W:
[IMG]local://upfiles/73451/4BB068DE22184CBEA46587201FD04760.jpg[/IMG]
[IMG]local://upfiles/73451/385D72D03D3841F7924A8EB13E1F756F.jpg[/IMG]
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
teeeeg67
Sep 1, 2015 11:53 PM
steelers743
Aug 31, 2015 07:16 AM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
89blueslug
Aug 10, 2015 07:20 AM
