Center Link Removal???
Old Aug 16, 2007 | 06:09 PM
coda618's Avatar
coda618
Default Center Link Removal???
Hey guys, I have all new manual steering parts for my 67 coupe. The only part I will be keeping is the piman arm as it looks to be in good condition. The rubber is still there between the pitman arm and the center link so I think it is ok, unles someone recomend replacing it anyway.
So, I have all the steering out with the exception of the idler arm center link and pitman arm. What I would like to know is what is the best way to separate the pitman arm from the center link. I have a pickle fork, but I think it will wind up destroying the rubber on the piman arm if I use it, so there must be another way. Any suggestions are appreciated.
Thanks
Old Aug 16, 2007 | 07:00 PM
66GTKFB's Avatar
66GTKFB
Default RE: Center Link Removal???
Tradition dictates the use of the pickle fork. The prefered method is with the nut almost completly off, give a couple of solid whacks (a technical term) on the side of the center link, not the end of the tapered fitting, and all shall be well. Method 2 is to pound the turned upside-down nut on theend of the tapered fitting with some type of support on the center link.
Jim
Old Aug 16, 2007 | 07:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Just throw the whole thing away and go with all new parts. You only get to do this once in your lifetime, so don't get chincy (technical term] and try to save some 40 year old part just because the rubber appears to still be good. Get real. If you were a 40 year old rubber, how good would you be.
Old Aug 16, 2007 | 07:12 PM
coda618's Avatar
coda618
Thank you.However, the nut is on the threaded stud of the pitman arm that comes up through the center link. How can I bang on that, the pitman arm is not going to go anywhere. The center link must come up off the stud?????When I removed the controll arms I did the rap method, unthreading the nut but leaving it on and then rapping the spindle with a small sledge til it dropped of the ball joint. That worked like a charm. But here, the pitman will not drop out as it is fixed on the steering box. If I rap the center link will it free it?
Old Aug 16, 2007 | 07:16 PM
coda618's Avatar
coda618
Yeah, you are right soaring.But I was told that it was a non-wear item and not to replace it. But I am thinking thats the way to go. Only issue is they are like $130 bucks at advance auto and they have a core charge, which suprised me, of 100 bucks. So I will have to sep it anyway.
Old Aug 16, 2007 | 07:30 PM
Soaring's Avatar
Soaring
I ♥ Acer
Ah, what the hey.....I lose 130 bux everytime I play poker. You need to get a bfh and whop the hell out of it. It will eventually come apart.
Old Aug 16, 2007 | 07:57 PM
restomod@16's Avatar
restomod@16
I love taking hammers and just WHAPPING stuff!
Old Aug 16, 2007 | 08:02 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
here you go link explaining how to whack the pieces http://www.mustangsplus.com/tech/sho...shockfall1.htm
Old Aug 16, 2007 | 08:07 PM
dodgestang's Avatar
dodgestang
Poker game at my house next Tuesday...who's coming besides soaring?
Old Aug 16, 2007 | 08:09 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well if i was way over there id come :P but im a few thousand miles away
