finding a 9in rear
Old Aug 16, 2007 | 09:43 PM
golgiapp.'s Avatar
golgiapp.
Default finding a 9in rear
where can i find a 9in rear end that will bolt directly to a 67 coupe with very little/no modifications?
Old Aug 16, 2007 | 09:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: finding a 9in rear
They are getting harder and harder to find.
http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
Old Aug 16, 2007 | 10:07 PM
JMD's Avatar
JMD
Currie will make one that fits perfectly,,,, for some $$....
Old Aug 16, 2007 | 10:39 PM
nealro's Avatar
nealro
I'm far too poor/stingy to buy a Currie or Strange... I usually start looking in junkyards and swap meets. Course you'd be hard pressed to find a direct bolt in... but if you do it's way cheaper to clean up an old one than to get a fresh aftermarket piece. The rear-end I stuck in my '68 for example is like an inch longer which is no big deal at all but the spring perches did have to be cut off and moved in a bit, that's likely about as close as you'd come to a bolt in with that route, If you can weld or have a buddy that can do it (like I did) that's a 1 hour job. Beyond that it was grinding and painting.
Old Aug 16, 2007 | 10:42 PM
andrewmp6's Avatar
andrewmp6
cheapest place to get a 9inch id turst is http://www.perogie.com/Rears.htm he will sell you a good used one or rebuld it for you anyway you like
Old Aug 17, 2007 | 06:54 AM
crzipilot's Avatar
crzipilot
Haven't looked to see how price competitive, but there's a guy on ebay that has 9" housings for around 300.00 Think a set of moser axles are another 2-300, have not idea on customer service or anything, have just seen his auctions....
Old Aug 17, 2007 | 07:29 AM
bluovalguy's Avatar
bluovalguy
Two months ago I think, Mustang Monthly had a crate rear on the cover. It was the mag with the Bullit on the cover I believe. I'm not in the market, so I didnt pay attention to the price, sorry.
Old Aug 17, 2007 | 07:38 PM
baddog671's Avatar
baddog671
ORIGINAL: crzipilot
www.quickperformanceracing.com
Here's his qoute for me...
Nic-
Here is what we can do on a complete 9" Ford Rearend for your 67 Mustang:
$650 - 9" Housing/Axle Package (67 Mustang)
- Moser Axles, Axle Bearings, Wheel Studs, & Retainers
- 31 Spline, 5 on 4-1/2" Bolt Pattern, 1/2" Studs
$820 - Center Section (Assembled)
- New 31 Spline Trac-Lock Posi
- New Motive Performance Gears (3.50)
- New Timken USA Bearings
$369 - 11" Disc Brake Kit w/ Parking Brake ($239 w/out parking brake)
$1839 - TOTAL
This would be a complete 31 spline setup with your choice of gear ratio. We use new Moser axles (not factory re-splines). We also use new trac-lock posi units, not torque-lock units (modified open carrier) like others have been selling on eBay.
This center section would be good up to 500HP. If you plan on having more than that you will want to go to an aftermarket setup. It would be $1125 instead of $820 for a complete center with the Strange Nodular Iron S-Case, Aluminum or Iron Daytona Pinion Support, 1350 Steel Yoke, Motive Performance Gears, 31 Spline Trac-Lock Posi, & Timken (USA) Bearings. ALL NEW & ASSEMBLED!
Let me know if you have any other questions.
Thanks,
BRYDON
641-751-8060
drfister
May 3, 2018 10:38 PM
musnicki
Sep 23, 2015 07:11 AM
whatsup62
Sep 3, 2015 01:38 PM
bluovalguy
Aug 24, 2015 08:20 AM
Daleford
Aug 10, 2015 08:30 PM
