Instrument panel lights
Old Aug 17, 2007 | 01:32 AM
Timelockmind's Avatar
Timelockmind
Default Instrument panel lights
Does anyone know if the instrument panel lights have an assembly that can be replaced? My reoccuring problem is that half of my panel is dimmer than the other and, while driving, the weaker half will just fade to blackness.
I have had it looked at twice and the bulbs are all working. Is there a seperate light assembly that cna be replaced? We juts can't figue put what he problem is.
Any suggestions?
Old Aug 17, 2007 | 02:00 AM
groho's Avatar
groho
Default RE: Instrument panel lights
you might be looking in the wrong place. use a jumper if possible and apply 12V direct to power side feeding the instrument light to make sure it's good. They should stay solid. I would think the dimmer portion of the light switch would be suspect suspect.
Old Aug 17, 2007 | 08:32 AM
dnswwood's Avatar
dnswwood
Isn't there a resistor or something on the back of the dash on the plastic grid? Not sure it has anything to do with the panel lights but it might be something to look into
Old Aug 17, 2007 | 09:10 AM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
I had the same problem with my 70; I replaced the circuit board on the back and it fixed it.
Old Aug 17, 2007 | 11:44 AM
66GTKFB's Avatar
66GTKFB
ORIGINAL: Timelockmind
Any suggestions?
First, what year car. I stopped reading minds years ago. Different years have different problems.
Common problems.
Second - there is a ground wire from the instrument panel wiring to the dash structure that is prone to giving problems.
- Solution - Remove wire, clean terminal, screw and dash metal where it attaches. Add an external tooth lock washer for better contact.
Third - the wire wound resistor in the headlight switch gets worn out.
- Solution -Replace the switch.
Jim
Old Aug 17, 2007 | 12:10 PM
Art Brock's Avatar
Art Brock
Had a similar dimming dash light problem in my 66 Coupe. Replaced the headlight switch & works great now. Cost less than $20 for a new switch.
jwog666
Dec 27, 2021 08:09 PM
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Explosive
Oct 2, 2015 07:45 AM
b8checker
Sep 30, 2015 07:11 AM
