Autolite 4100
Old Aug 17, 2007 | 06:53 AM
M. Dunn's Avatar
M. Dunn
Default Autolite 4100
I am burning very rich starting up with lots of black soot. I installed the right jets, lowered the float level a bit and adjusted the choke. It is still blowing black soot when started and some reduced soot as the engine warms up. Anything I can check to solve this problem? Possibly the choke linkage is holding the throttle open that needs some type of adjustment. This is on a 66 GT. Anyone have another suggestion?
Thanks,
Mike
Old Aug 17, 2007 | 11:35 AM
coda618's Avatar
coda618
Default RE: Autolite 4100
Don't know what the black soot means, but, do you also have a strong smell of fuel? If so, lean out the idle mixture.General bench adjustment is to turn the mixture screws all the way in and then back out 1 1/2 turns. Then fine tune.If you have a shop manual, I would got throught the set up procedures.
TfcCDR
Sep 12, 2015 04:13 PM
skiprCH
Aug 16, 2007 02:56 PM
skiprCH
Jan 1, 2006 08:20 PM
skiprCH
Sep 4, 2005 02:32 PM
64preproduction
Dec 20, 2004 03:28 PM
