cam question
Old Aug 18, 2007 | 02:22 PM
67mustang302's Avatar
67mustang302
Default RE: cam question
As far as the Summit cam/valvetrain stuff, I've heard that it's manufactured by Crane. And I wouldn't use new lifters on a used flat tappet cam since the lifters and lobes wear together, then you're mixing a worn lobe with an unworn lifter and it may put excess force on some spots and eat it up. But I've heard of people doing it and being fine. Another reason I like roller cams, ain't gotta worry about stuff like that
Old Aug 31, 2007 | 08:40 AM
unitedwestand's Avatar
unitedwestand
I have narrowed it down to these:
Comp Cams 31-432-8 & 31-442-8
Crane 369541
Opinions?
Thanks
Old Aug 31, 2007 | 11:46 AM
67mustang302
I'd go with the Crane grind. It's similar to the one I'm running. It's a dual pattern with a bit wider lobe seperation so it'll make good torque everywhere and drive well on the street, but still make good top end power. Broad torque. The Comp grids would be good too, but since they're single pattern with tighter lobe seperation it'll make a bit more peak power, but won't have as broad a power range as the crane grind would. That Crane grind with some good heads will make plenty of power. And hydraulic roller conversion cams are quite a bit pricier, just so you know. You'll spend a fair chunk on conversion lifters, but again, I think the benefits of roller cams outweigh the costs.
Old Aug 31, 2007 | 11:57 AM
unitedwestand
Thanks
I'm using a set of Ford Motorsport lifters for a 5.0 liter block. I was told they will work as long as I get the locks and girdle.
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
