one wire alt conversion
Old Aug 17, 2007 | 01:30 PM
groho's Avatar
groho
Default one wire alt conversion
I've heard the one-wire alternater conversion is a simple swap that is supposed to make some noticable, seat of your pants, performance improvements in the ignition area, especially if you're running a pertronics, MSD, etc. Speaking to the folks that have made this alternator change, is this true? My factoryalternator/regulator setup on my '66 coupe, 289 workingfine. I'm just wondering ifit's worth it
from a performance perspective, or is it just a convenience. Also, what additional changes need to be made to thevolt meterin the dash to accomodate the change? How easy is it to pull out the old wiring for the voltage regurlator?
Old Aug 17, 2007 | 03:17 PM
jlg2002's Avatar
jlg2002
Default RE: one wire alt conversion
If you need more amps than what you currently have available, it's a solution. The main engine compt wire harness on my 66 would have to be altered to either stow the V Reg plug or cut it off and hide the wires in the loom. According to my cars wiring diagram, removalof the V reg will not affect the ammeter operation.
Old Aug 17, 2007 | 03:49 PM
jspagna1's Avatar
jspagna1
Thisis the one I got for my car. I left the voltage regulator in it's place, and just bypassed it. You do need to make sure the car does not idle under 1500 RPM for any long period of time or you will kill your battery.
[align=center]
ALTERNATOR 65/78 MUSTANG W/ V-BELT 140 AMP CHROME
Powermaster 140-Amp Alternator, Chrome for 1965-1978 Mustang.
This chrome alternator really puts out the juice. Whether its to supply that high power stereo or massive electric fuel pump, it provides the performance for whatever you the need the current for. It is internally regulated and hooks up easily with only the included single 6-gauge charge wire. Chrome v-belt pulley is included.
[/align]
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
