Coil Spring help
Old Aug 18, 2007 | 01:21 PM
BakoLuke's Avatar
BakoLuke
Default Coil Spring help
on my '66 the coil spring isnt centered. the shock is almost rubbing the spring and its making a terrible squeaking noise. Im not sure what to call it but is there a "perch" that the spring sits on? and if so whats the proper name? my book calls it a 5355 but that means nothing to me...
any help is greatly appreciated
Luke
Old Aug 18, 2007 | 01:35 PM
mat11089's Avatar
mat11089
Default RE: Coil Spring help
Yes and it is called a perch.You oughta drop the spring and center it.
Old Aug 18, 2007 | 04:42 PM
baddog671's Avatar
baddog671
The spring should be sitting on the spring perch, also called a spring saddle, which also acts as a pivet point. Is it not there and just sitting on the control arm, or is it not settled on the perch correctly?
Compress the spring and move it..
Old Aug 18, 2007 | 06:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you have your front end jacked up, you won't have to compress the spring but just a tad to get it to move. Stick it back in the perch. *I'm wondering how in hell it got out of the perch*
Old Aug 18, 2007 | 07:00 PM
66GTKFB's Avatar
66GTKFB
ORIGINAL: Soaring
Gravity, simply gravity - or the Earth sucks.
firehorse02
Nov 16, 2015 11:28 AM
mungodrums
Sep 28, 2015 10:54 PM
Sixer4Life
Sep 28, 2015 07:05 AM
lmurf60
Sep 24, 2015 10:07 PM
