HIPOPARTS LED GUAGES FOR A 1970 MUSTANG?
Old Aug 21, 2007 | 01:01 AM
1970coupe's Avatar
1970coupe
Default HIPOPARTS LED GUAGES FOR A 1970 MUSTANG?
Hello i currently have no dash lights in my coupe but my guess is they are burnt out and the guy before me didnt change them. Well anyway i was looking at a red led light kit for my 70 coupe by hipoparts. Any suggestions? Is this a good kit and is it fairly easy to fix the dash lights to work? Please reply soon!
Old Aug 21, 2007 | 02:25 AM
IM RICKY BOBBY's Avatar
IM RICKY BOBBY
Default RE: HIPOPARTS LED GUAGES FOR A 1970 MUSTANG?
i have a 69 and im pritty sure there the same as the 70. as far as changing the bulbs its easy. you turn the bulbs a half turn and they lock in. im not to know too much about the kit ur wanting to purches but i hope this helps
Old Aug 21, 2007 | 02:41 AM
1970coupe's Avatar
1970coupe
do you have to take the whole dash out?
Old Aug 21, 2007 | 03:20 PM
1970coupe's Avatar
1970coupe
anyone know if i need to take the whole dash out to change the bulbs?
Old Aug 21, 2007 | 03:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you look at your gauge cluster closely, you will see screws holding it in. But, the first thing you should do is to check each and every one of your fuses. Now, if all your fuses are OK, take out the gauge cluster, then take off one of the wires from something like the Gen light, then turn the key on and use a multi-meter gauge to see if you have any juice to that socket. If you do, then the bulb is burned out. Hold the bulb up to the light and see if the tiny wire is burned out or still there. If the bulb is burned out, the little wire will be burnt into.
Diode Dynamics
28
May 26, 2022 12:02 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
inyadreems
Aug 21, 2015 09:10 AM
daytooday
Aug 11, 2015 09:22 AM
mustangsrforever!!!
Aug 6, 2015 12:04 PM
