checking the cowl ?
Old Aug 21, 2007 | 01:36 AM
eep4life's Avatar
eep4life
Default checking the cowl ?
i read in another posting ... something about the cowl... soaring said that when looking at a possible buy check the cowl by pooring a gallon of water over it.... so real quick if the cowl is good the water will run out of the car from where... and if it is bad it will run into the car?
Old Aug 21, 2007 | 01:47 AM
ShAkE N BaKe!!'s Avatar
ShAkE N BaKe!!
Default RE: checking the cowl ?
If its good, I dont know where it goes out through, but if its bad, like smoe of ours, it will run into the car down the kick panels(by your feet) and into the carpet![:@]
Old Aug 21, 2007 | 06:23 AM
JamesW's Avatar
JamesW
If it's good, it will run out behind the fenders between the front of the door and the rear of the wheel opening. The cowl has a small dump on each side where the water escapes. If it's bad, typically it's rusted around the vent "hats" on either side of the dash. Look up under on the driver's side where the air vent is bolted to the cowl, and on the pass side behind the glovebox where the heater box is bolted to the cowl. Either of these could allow water to run down the firewall and onto the floor.
Nov 18, 2015 01:34 PM
StalkerGT
Sep 25, 2015 02:41 PM
gagemcc
Sep 22, 2015 09:43 AM
Ipaman
Sep 22, 2015 07:01 AM
Sep 10, 2015 07:23 PM
