quick question
Old Aug 21, 2007 | 05:41 PM
Mustang.'s Avatar
Mustang.
Default quick question
i am looking a buying a new engine for my '65 mustang and was wondering if it would work (fit in the car and will it work with my tranny). here is a clip from the listing "ford 289 small block, bored .060 over, fully balanced, high compression pistons, gear drive, big cam, solid lifters, roller rockers, dual valve springs, ported heads and intake, edelbrock intake, headers, high flow water pump, no carb. built for race car". thank you in advance.
Old Aug 21, 2007 | 05:51 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: quick question
quick answer - no
[ol][*]built for race car[*]high compression does not mix well with pump fuel[*]bored .060 - makes for pretty thin cylinder walls on a 289 which makes keeping it cool difficult.[/ol]
Old Aug 21, 2007 | 05:55 PM
JPaikos's Avatar
JPaikos
I wouldn't hot rod a motor that was .060 over. Thin cyndeler wall's = boom. Not if, but when.
Old Aug 21, 2007 | 05:59 PM
dcohen's Avatar
dcohen
yea, that motor has been overly built, wouldnt be very reliable
Old Aug 21, 2007 | 06:23 PM
66GTKFB's Avatar
66GTKFB
Gee on this thread, a0.060 inch overbore is no good, on another, 0.060 inch was fine. Get your acts together. (I'm in the 0.060 inch overbore is too much camp. You own a boat anchor.)
JIm
Old Aug 21, 2007 | 06:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
I agree Jim.
Old Aug 21, 2007 | 06:32 PM
coda618's Avatar
coda618
+1000
Old Aug 21, 2007 | 06:42 PM
gothand's Avatar
gothand
Funny, I was thinking the same thing and then got to Jim's post. Where are the 0.060 supporters?
To the O.P., I'll quickly summarize amistake I recently made that cost me about $1000, and more importantly, my time and sanity! When looking to get a new motor for my fastback (I was pulling out a 351W so I was starting from scratch), I made the mistake of looking at all these high power numbers that people are obtaining without fully thinking out how streetable it would be. I bought a crate motor that had large heads, large lift cam andhigh compression, etc. It was going to be a screamer on the track but was going to need damn near 3.89 gears and 3000+ rpm before it would get out of its own way. Ultimately, the engine had a rear main seal leak that wouldn't stop so I negotiated a return.
I ended up doing what I originally planned on doing prior to being seduced by the 'numbers' and bought an all new Ford Racing crate motor. So what if it is only rated at 345 hp, it is still more than I need. Best of all, it is very street friendly and is a Ford. I'm not saying that this engine is necessarily the engine for you, rather to clearly think out your desired results prior to leaping.
Good luck!
Jeff
Old Aug 21, 2007 | 06:46 PM
66GTKFB's Avatar
66GTKFB
ORIGINAL: gothand
Good luck!
Jeff
Sanity returns.
Jim
Old Aug 21, 2007 | 06:52 PM
Aussie66Fastback
ORIGINAL: 66GTKFB
JIm
who says 060 is ok?
my understanding is that the issue leads more towards "hot spots" b/c the walls are thinner (thus making for uneven temperatures in different parts of the block) rather than making the motor weaker.
what's your take?
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
