electric choke
Old Aug 22, 2007 | 03:35 PM
geddylee's Avatar
geddylee
Default electric choke
How do you hook up the electric choke on a 600 edelbrock? The choke or something with the carb is causing it not to idle down when hot rodded a little bit.
Old Aug 22, 2007 | 04:12 PM
66GTKFB's Avatar
66GTKFB
Default RE: electric choke
Here we go again. On a 64 to 68 with a regular heater, switched 12 volts can be obtained under the hood from the brown lead that goes to the heater blower. You can make a 'Y' type jumper cable by using a male 0.187 inch bullet connector and a female 0.187 inch bullet connector at each end of the 'Y', and thenrunning a longer (about 15 inches) wire crimped into one of those bullets to whatever type of terminal that's on the electric choke.
Jim
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
allenmaty
Sep 24, 2015 09:17 AM
uberstang1
Sep 20, 2015 06:42 PM
TfcCDR
Sep 14, 2015 12:08 PM
